link to pokeer sample
hkausl
I read in several threads about the pokeer sample. Is there a link, where I can find this sample?
Kevin_D_Intel
The Poker sample ships with the Intel Visual Fortran compiler. Look under your IVF installation area C:\Program Files (x86)\Intel (64-bit OS) or C:\Program Files\Intel (32-bit OS)under the Samples folder in the QuickWin.zip file.
For example:
C:\Program Files (x86)\Intel\Compiler\11.1\060\Samples\en_US\Fortran\QuickWin.zip\QuickWin\Poker
There is a summary of all the Samples provided with IVF available in the file: [IVF installdir]\Samples\en_US\Fortran\samples.html
hkausl
That's my problem, I don't have the sample folder. Perhaps I din't install it. Is there a link to the samples on the Intel-Homepage?
Kevin_D_Intel
Interesting...Its not a selectable component during the installation, they're always installed. Sorry, there's no link within the Intel network to them. They are a part of the compiler installation package only.
What version of IVF do you have installed?
hkausl
It's version 8.1. Can you attach the sample to post?
Kevin_D_Intel
That explains why they're missing. They first appeared in the 10.x release. Sorry, no I cannot simply attach it due to the usage restrictions on the Samples source code.
Given you have 8.1, I expectyour support subscription is long expired (unless you've been renewing annually) so you can purchase a new IVF subscription or consider a 30-day free evaluation. If you've been renewing and your subscription is current, then download the latest 11.1 Update 5 from the Intel Registration Center to obtain the samples.
