29315 Discussions
Missing 32 bit HPC toolkit for 2023.0 oneAPI
Andrew_Smith
Valued Contributor I
Is this available or no longer supported? There is no download link
Andrew_Smith
I need to target 32 bit windows occasionally. Build MC is 64 bit.
I now see I can already do this, and it was my misunderstanding. I thought the 32 bit base toolkit needed to be paired with a 32 bit HPC in order to do this, but seams not. Case solved
Ron_Green
I don't understand.
Do you want to use the compiler on a very old 32bit OS PC?
Or do you want to compile 32bit binaries that will be deployed to a 32bit machine?
Windows or Linux?
You can still target 32bit machines, you just cannot run the tools on 32bit machines.
Andrew_Smith
JohnNichols
Valued Contributor III
The 32 bit MKL and something else would not fit into the base kit, so Intel made a second base kit.  That is the urban myth from Intel.  It sounds reasonable.
I am updating the base kit on a NUC at the moment and it just failed to update, blast and tarnation, the Dodgy Bros. strike again.
As I watch the update I have some spare time, I do not want to jinx it, so I am just reading the posts and enjoying myself.
