Missing Help Files with 11.1.035
bruppel1
Hello, I recently downloaded and started using the 11.1.035 IVF Pro package, with the VS 2008 shell. I installed it without uninstalling my previous installation which used VS 2005 Premier Partner Edition.
In the new VS2008 shell, when I go to Help > Intel Visual Fortran Compiler Pro Help > Intel Visual Fortran Compiler Help, the help browser opens and tells me that "information not found." When I go to search, and look at the list of availible languages, Fortran is not listed.
When I go to the start menu and select the Documentation link, select Intel Visual Fortran Compiler Documentation, and select "alternate help format: main_for.chm", I get a help file where there is a working list of index, table of contents, etc in the left pane, but originally, when I selected an item from the left side, the right side wouldn't loaded any information. I did a Repair installation, and now the main_for.chm file works, but the help from the IDE help browser still does not work. Anyone have any tips?
bruppel1
Okay, I installed the newer version .038 and now the help file works.
