29273 ディスカッション
Missing c++ library?
killuah
ビギナー
548件の閲覧回数
Hello and thanks for reading.
I am trying to get the newest Fortran compiler working with Ubuntu.
I installed the compiler and set the variables via source /opt/etc...
Now whenever I try to compile a source file, I get
/opt/intel/Compiler/11.1/056/bin/ia32/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
ifort: error #10273: Fatal error in /opt/intel/Compiler/11.1/056/bin/ia32/fortcom, terminated by 0x7f
What am I missing? I already tried reinstalling the c++ libraries but that did nothing...
Thanks for reading again
0 件の賞賛
2 返答(返信)
Steven_L_Intel1
従業員
548件の閲覧回数
Which specific Linux distro and version are you using?
The Release Notes contain details of what is required. You probably need compat-libstdc++.
TimP
名誉コントリビューター III
548件の閲覧回数
The note on Ubuntu at the top of the forum specifies the apt-get command which should install libstdc++.so.5. While red hat calls it compat-libstdc++, the other distros use different names. This library is required in addition to the more current versions which g++ requires.
返信
