Missing quotes in tbbvars.sh
Guido_K_
I am encountering the following problem on tbbvars.sh script of Linux Composer XE
opt64/intel/tbb/bin/tbbvars.sh :
1     get_library_directory(){
2     gcc_version_full=`gcc --version | grep "gcc"| egrep -o " [0-9]+\.[0-9]+\.[0-9]+.*" | sed -e s/^\ //`
3     ...
13    }
The missing quotes around the substitute lead to an error when starting zsh (v5.0.2 from OPENsuse 12.3); bash has does not show the problem.
get_library_directory:1: no matches found: s/^ //
I suggest to use quotes and replace line 2 with
2     gcc_version_full=`gcc --version | grep "gcc"| egrep -o " [0-9]+\.[0-9]+\.[0-9]+.*" | sed -e "s/^\ //"`
ifort (IFORT) 14.0.2 20140120
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Linux 64bit
Kernel version 3.7.10-1.16-desktop
Guido K.
Kevin_D_Intel
Thank you for reporting this issue Guido. I forwarded this to the TBB Development team (see internal tracking id below) for investigation/consideration and will keep you updated regarding a fix in a future release.
(Internal tracking id: DPD200256963)
Vincent_Lefevre
I installed Intel Cluster Studio XE 2015 yesterday, and found the same problem (I'm also using zsh, which regards ^ as a special character in some configuration). I'd suggest the following solution:
gcc_version_full=`gcc --version | grep "gcc"| egrep -o " [0-9]+\.[0-9]+\.[0-9]+.*" | sed -e "s/^ //"`
i.e. adding quotes for the sed expression as already suggested, but also removing the backslash (which should no longer be there due to the added quotes, though it is harmless I think).
Kevin_D_Intel
Yes, this defect is still unresolved. Thank you for the ping and revised suggested solution. I passed that on to the TBB Development team.
