Mix variable type in fortram
pfwang
How can I mix two variables with different types in fortran. I intend to have a fixed name (character) such as Name1 = "File". Another variable, Number, will be defined as a variable (character) which may change by model input or within the code. For example, Number may begivenas"1", "2", or "1001","3001".Then I need to combine Name1 and Number so that the newvariable (Name2)is named as "File1", or "File2", or "File1001", or "Filr3001", which are obtained by adding Name1 ("File") and Number ("1", :2", "1001", or "3001").
Do you know how to do it?
It is not completely clear to me what you want to do.
Do you want to create a character variable whose value consists of a fixed prefix and a variable suffix? If so, then you use the "internal write" feature to do that, for example:
character(10) name
write (name,'(A,I0)') 'File', 1001
When run, this assigns the value 'File1001' to variable "name".
If you actually want to create a Fortran variable this way, so that the name of the variable changes at run-time, no, you can't do that.
jimdempseyatthecove
Consider using the '//' operator
character(10) name
character(4)Anumber
integer number
number = 1234! pick up integer number
write(Anumber,100) number
100 format(I0)
name ='File'//Anumber
Anumber = ':2'
Jim Dempsey
pfwang
Thanks, Jim. Your example work well if the input (number) is an integer. What if my input is characters or strings (such as, ":Case #1", or ":Case #A100"), which is Anumber in your example, which will be input from screen by the users? In other words, I hope to have the following:
name=File:Case #1 ; or
name=File:Case #100
Any more ideas?
The use of "internal write" as in my example (and part of Jim's) gives you extraordinary flexibility for how you construct strings. You can use any of the formatting you would use to write to a file. If you want to include strings, use the A format.
jdchambless
Hi Steve,
Would you mind letting me know where to find the formatting flags that you put in the quotes in your WRITE statement? (e.g. the '(A,I0)' part of "write (name,'(A,I0)') 'File', 1001")
Jason C.
That's a standard Fortran format - look at the documentation for "I/O Formatting" in the Intel Fortran Language Reference. The Fortran language allows you to put a format as a character constant (or variable!) in place of a FORMAT label in an I/O statement. Anything valid in a FORMAT can go here. Don't forget the parentheses at each end, as they're required.
