Mixed Language (C Calls Fortran)
kulachi
I am creating a Mixed Language Solution with a Fortran Static LIB. I have done it a dozen times before, and to a significant degree of complexity, but after being away for a while, I am rusty.
I have created a Multiproject solution, added to it a static LIB fortran project, and then a C++ project. I have further done the following:
A. Made sure that VS2005 SP1 is installed (I am using Microsoft Visual Studio 2005)
B. Added Static LIB as Dependent of C/C++ project
C. In Tools > Options > Projects > VC++ Directories > Library Files, I added Intel Fortran LIB
D. Made sure that both projects use Multithreaded Debug DLL Libs
However, when I compile the solution, I get the following error:
1>------ Rebuild All started: Project: FTRN, Configuration: Debug Win32 ------
1>Deleting intermediate files and output files for project 'FTRN', configuration 'Debug|Win32'.
1>Compiling with Intel Fortran Compiler 10.1.021 [IA-32]...
1>Source1.F90
1>Creating library...
1>
1>Build log written to "file://C:\TCPIP_SRCL\Lib4\FTRN\Debug\BuildLog.htm"
1>FTRN - 0 error(s), 0 warning(s)
2>------ Rebuild All started: Project: Lib4, Configuration: Debug Win32 ------
2>Deleting intermediate and output files for project 'Lib4', configuration 'Debug|Win32'
2>Compiling...
2>CC.cpp
2>Compiling manifest to resources...
2>Linking...
2>CC.obj : error LNK2019: unresolved external symbol _Parser referenced in function _main
2>MSVCRTD.lib(crtexew.obj) : error LNK2019: unresolved external symbol _WinMain@16 referenced in function ___tmainCRTStartup
2>C:\TCPIP_SRCL\Lib4\Debug\Lib4.exe : fatal error LNK1120: 2 unresolved externals
2>Build log was saved at "file://c:\TCPIP_SRCL\Lib4\Lib4\Debug\BuildLog.htm"
2>Lib4 - 3 error(s), 0 warning(s)
========== Rebuild All: 1 succeeded, 1 failed, 0 skipped ==========
It looks like Fortran Static Lib is not being picked up by the executable project. I have opened up on of my old working mixed language projects, and cross-checked almost everything. I simply can't figure out what is the problem here.
-Kulachi
Fortran created the name _FCODE. If you want it to be _Fcode add:
!DEC$ ATTRIBUTES DECORATE,ALIAS:"Fcode" :: Fcode
to the Fortran source. Ordinarily I might suggest BIND(C,NAME="Fcode") but you have not coded your Fortran to be compatible with that so let's skip it.
Look at the actual BuildLog.htm and examine the command line passed to LINK. Does it reference your library? I have sometimes seen where even adding the Fortran library as a dependent project doesn't cause the parent to link it in. I have never figured out a specific cause of this and it is rare enough that when I do encounter it I just add the library manually.
Of course, it's possible that the library is referenced and the symbols don't match.
Should the Fortran project resolve _WinMain@16?
kulachi
Much obliged Steve!
I spent another 3 hours but no success. Here is some more detail on this.
The source code:
C/C++:
#include
#include
#ifdef __cplusplus
extern "C"
#endif
void FCode(char *STR_OUT, size_t STR_OUT_LEN);
int main(int argc, char *argv[]) {
char String[] = "Hello";
FCode(String, sizeof(String));
Fortran:
SUBROUTINE FCode (String)
IMPLICIT NONE
CHARACTER(*), INTENT(IN) :: String
WRITE(*,*) String
END SUBROUTINE FCode
Now, I specifically added the LIB in C/C++Project > Properties > Additional Include Directories, and set C/C++Project > Properties > Linker > General > Show Progress to /VERBOSE. This gave me the following (rather lengthy) build log:
1>------ Build started: Project: Lib1, Configuration: Debug Win32 ------
1>Lib1.F90
1>
1>Build log written to "file://C:TCPIP_SRCLYetAnotherLib1DebugBuildLog.htm"
1>Lib1 - 0 error(s), 0 warning(s)
2>------ Build started: Project: YetAnother, Configuration: Debug Win32 ------
2>Compiling...
2>CC.cpp
2>Linking...
2>Starting pass 1
2>Processed /DEFAULTLIB:MSVCRTD
2>Processed /DEFAULTLIB:OLDNAMES
2>Searching libraries
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libkernel32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libuser32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libgdi32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libwinspool.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libcomdlg32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libadvapi32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libshell32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libole32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Liboleaut32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libuuid.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VCPlatformSDKlibodbc32.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VCPlatformSDKlibodbccp32.lib:
2> Searching ..lib1debuglib1.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VClibMSVCRTD.lib:
2> Found __imp__printf
2> Referenced in CC.obj
2> Loaded MSVCRTD.lib(MSVCR80D.dll)
2> Found ___security_cookie
2> Loaded MSVCRTD.lib(gs_cookie.obj)
2> Found @__security_check_cookie@4
2> Loaded MSVCRTD.lib(secchk.obj)
2> Found @_RTC_CheckStackVars@8
2> Loaded MSVCRTD.lib(stack.obj)
2> Found __RTC_Shutdown
2> Loaded MSVCRTD.lib(init.obj)
2> Found _mainCRTStartup
2> Loaded MSVCRTD.lib(crtexe.obj)
2> Found __IMPORT_DESCRIPTOR_MSVCR80D
2> Referenced in MSVCRTD.lib(MSVCR80D.dll)
2> Found ___report_gsfailure
2> Referenced in MSVCRTD.lib(secchk.obj)
2> Loaded MSVCRTD.lib(gs_report.obj)
2> Found "void __cdecl _RTC_Failure(void *,int)" (?_RTC_Failure@@YAXPAXH@Z)
2> Referenced in MSVCRTD.lib(stack.obj)
2> Loaded MSVCRTD.lib(error.obj)
2> Found __RTC_SetErrorFuncW
2> Referenced in MSVCRTD.lib(init.obj)
2> Loaded MSVCRTD.lib(userapi.obj)
2> Found __CRT_RTC_INITW
2> Found __forceCRTManifest
2> Referenced in MSVCRTD.lib(crtexe.obj)
2> Loaded MSVCRTD.lib(crtmanifest.obj)
2> Found ___CxxSetUnhandledExceptionFilter
2> Loaded MSVCRTD.lib(unhandld.obj)
2> Found __imp___configthreadlocale
2> Found ___globallocalestatus
2> Loaded MSVCRTD.lib(xthdloc.obj)
2> Found __setdefaultprecision
2> Loaded MSVCRTD.lib(fp8.obj)
2> Found __imp____setusermatherr
2> Found __matherr
2> Loaded MSVCRTD.lib(merr.obj)
2> Found __setargv
2> Loaded MSVCRTD.lib(dllargv.obj)
2> Found __RTC_Initialize
2> Loaded MSVCRTD.lib(initsect.obj)
2> Found __adjust_fdiv
2> Loaded MSVCRTD.lib(adjustfd.obj)
2> Found __imp___adjust_fdiv
2> Found __commode
2> Loaded MSVCRTD.lib(xncommod.obj)
2> Found __imp____p__commode
2> Found __fmode
2> Loaded MSVCRTD.lib(xtxtmode.obj)
2> Found __imp____p__fmode
2> Found ___onexitbegin
2> Loaded MSVCRTD.lib(atonexit.obj)
2> Found __imp___encode_pointer
2> Referenced in MSVCRTD.lib(atonexit.obj)
2> Found __imp____set_app_type
2> Found __amsg_exit
2> Found __imp____getmainargs
2> Found __dowildcard
2> Loaded MSVCRTD.lib(wildcard.obj)
2> Found __newmode
2> Loaded MSVCRTD.lib(_newmode.obj)
2> Found ___security_init_cookie
2> Loaded MSVCRTD.lib(gs_support.obj)
2> Found __imp___exit
2> Found __XcptFilter
2> Found __imp___cexit
2> Found __imp__exit
2> Found __imp____initenv
2> Found __imp___CrtSetCheckCount
2> Found __IsNonwritableInCurrentImage
2> Loaded MSVCRTD.lib(pesect.obj)
2> Found __imp___CrtDbgReportW
2> Found __initterm
2> Found ___xc_a
2> Loaded MSVCRTD.lib(cinitexe.obj)
2>Processed /DEFAULTLIB:kernel32.lib
2> Processed /DISALLOWLIB:libc.lib
2> Processed /DISALLOWLIB:libcd.lib
2> Processed /DISALLOWLIB:libcmt.lib
2> Processed /DISALLOWLIB:libcmtd.lib
2> Processed /DISALLOWLIB:msvcrt.lib
2> Found __initterm_e
2> Found ___native_startup_state
2> Loaded MSVCRTD.lib(natstart.obj)
2> Found __except_handler4
2> Referenced in MSVCRTD.lib(error.obj)
2> Referenced in MSVCRTD.lib(pesect.obj)
2> Loaded MSVCRTD.lib(chandler4gs.obj)
2> Found __NULL_IMPORT_DESCRIPTOR
2> Found MSVCR80D_NULL_THUNK_DATA
2> Found __crt_debugger_hook
2> Referenced in MSVCRTD.lib(gs_report.obj)
2> Found "int __cdecl _RTC_GetSrcLine(unsigned char *,wchar_t *,unsigned long,int *,wchar_t *,unsigned long)" (?_RTC_GetSrcLine@@YAHPAEPA_WKPAH1K@Z)
2> Loaded MSVCRTD.lib(pdblkup.obj)
2> Found "void __cdecl terminate(void)" (?terminate@@YAXXZ)
2> Referenced in MSVCRTD.lib(unhandld.obj)
2> Found __controlfp_s
2> Referenced in MSVCRTD.lib(fp8.obj)
2> Found __invoke_watson
2> Found __unlock
2> Found ___dllonexit
2> Found __lock
2> Found __imp___onexit
2> Found __imp___decode_pointer
2> Found __except_handler4_common
2> Referenced in MSVCRTD.lib(chandler4gs.obj)
2> Searching C:Program FilesMicrosoft Visual Studio 8VClibOLDNAMES.lib:
2> Found __imp__InterlockedExchange@8
2> Loaded kernel32.lib(KERNEL32.dll)
2> Found __imp__Sleep@4
2> Found __imp__InterlockedCompareExchange@12
2> Found __imp__TerminateProcess@8
2> Found __imp__GetCurrentProcess@0
2> Found __imp__UnhandledExceptionFilter@4
2> Found __imp__SetUnhandledExceptionFilter@4
2> Found __imp__IsDebuggerPresent@0
2> Found __imp__RaiseException@16
2> Found __imp__DebugBreak@0
2> Found __imp__WideCharToMultiByte@32
2> Found __imp__MultiByteToWideChar@24
2> Found __imp__lstrlenA@4
2> Found __imp__GetProcAddress@8
2> Referenced in MSVCRTD.lib(pdblkup.obj)
2> Found __imp__LoadLibraryA@4
2> Found __imp__QueryPerformanceCounter@4
2> Referenced in MSVCRTD.lib(gs_support.obj)
2> Found __imp__GetTickCount@0
2> Found __imp__GetCurrentThreadId@0
2> Found __imp__GetCurrentProcessId@0
2> Found __imp__GetSystemTimeAsFileTime@4
2> Found __imp__HeapFree@12
2> Found __imp__HeapAlloc@12
2> Found __imp__GetProcessHeap@0
2> Found __imp__GetModuleFileNameW@12
2> Found __imp__VirtualQuery@12
2> Found __imp__FreeLibrary@4
2> Found __IMPORT_DESCRIPTOR_KERNEL32
2> Referenced in kernel32.lib(KERNEL32.dll)
2> Found KERNEL32_NULL_THUNK_DATA
2>Finished searching libraries
2>Finished pass 1
2> Found __load_config_used
2> Loaded MSVCRTD.lib(loadcfg.obj)
2>CC.obj : error LNK2019: unresolved external symbol _FCode referenced in function _main
2>C:TCPIP_SRCLYetAnotherDebugYetAnother.exe : fatal error LNK1120: 1 unresolved externals
2>Build log was saved at "file://c:TCPIP_SRCLYetAnotherYetAnotherDebugBuildLog.htm"
2>YetAnother - 2 error(s), 0 warning(s)
========== Build: 1 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Note that 2> Searching ..lib1debuglib1.lib: appears several times, but no Found word with it. Here is the Build Log for the C/C++ project:
Build Log:
Build started: Project: YetAnother, Configuration: Debug|Win32
Command Lines Creating temporary file "c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003747085136.rsp" with contents
/Od /I "C:TCPIP_SRCLYetAnotherLib1DebugLib1.lib" /D "_MBCS" /FD /EHsc /RTC1 /MDd /Fx /Fo"Debug" /Fd"Debugvc80.pdb" /W3 /c /Wp64 /TP .CC.cpp
Creating command line "cl.exe @c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003747085136.rsp /nologo /errorReport:prompt"
Creating temporary file "c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003847085136.rsp" with contents
/VERBOSE /OUT:"C:TCPIP_SRCLYetAnotherDebugYetAnother.exe" /INCREMENTAL:NO /LIBPATH:"C:TCPIP_SRCLYetAnotherLib1DebugLib1.lib" /MANIFEST /MANIFESTFILE:"DebugYetAnother.exe.intermediate.manifest" /DEBUG /PDB:"c:TCPIP_SRCLYetAnotherdebugYetAnother.pdb" /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "..lib1debuglib1.lib"
".DebugCC.obj"
Creating command line "link.exe @c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003847085136.rsp /NOLOGO /ERRORREPORT:PROMPT"
Any ideas?
-Kulachi
kulachi
I love you Steve!
