29282 Discussions
Mixed Language (C Calls Fortran)
kulachi
I am creating a Mixed Language Solution with a Fortran Static LIB. I have done it a dozen times before, and to a significant degree of complexity, but after being away for a while, I am rusty.
I have created a Multiproject solution, added to it a static LIB fortran project, and then a C++ project. I have further done the following:
A. Made sure that VS2005 SP1 is installed (I am using Microsoft Visual Studio 2005)
B. Added Static LIB as Dependent of C/C++ project
C. In Tools > Options > Projects > VC++ Directories > Library Files, I added Intel Fortran LIB
D. Made sure that both projects use Multithreaded Debug DLL Libs
However, when I compile the solution, I get the following error:
1>------ Rebuild All started: Project: FTRN, Configuration: Debug Win32 ------
1>Deleting intermediate files and output files for project 'FTRN', configuration 'Debug|Win32'.
1>Compiling with Intel Fortran Compiler 10.1.021 [IA-32]...
1>Source1.F90
1>Creating library...
1>
1>Build log written to "file://C:\TCPIP_SRCL\Lib4\FTRN\Debug\BuildLog.htm"
1>FTRN - 0 error(s), 0 warning(s)
2>------ Rebuild All started: Project: Lib4, Configuration: Debug Win32 ------
2>Deleting intermediate and output files for project 'Lib4', configuration 'Debug|Win32'
2>Compiling...
2>CC.cpp
2>Compiling manifest to resources...
2>Linking...
2>CC.obj : error LNK2019: unresolved external symbol _Parser referenced in function _main
2>MSVCRTD.lib(crtexew.obj) : error LNK2019: unresolved external symbol _WinMain@16 referenced in function ___tmainCRTStartup
2>C:\TCPIP_SRCL\Lib4\Debug\Lib4.exe : fatal error LNK1120: 2 unresolved externals
2>Build log was saved at "file://c:\TCPIP_SRCL\Lib4\Lib4\Debug\BuildLog.htm"
2>Lib4 - 3 error(s), 0 warning(s)
========== Rebuild All: 1 succeeded, 1 failed, 0 skipped ==========
It looks like Fortran Static Lib is not being picked up by the executable project. I have opened up on of my old working mixed language projects, and cross-checked almost everything. I simply can't figure out what is the problem here.
-Kulachi
Steven_L_Intel1
Fortran created the name _FCODE. If you want it to be _Fcode add:
!DEC$ ATTRIBUTES DECORATE,ALIAS:"Fcode" :: Fcode
to the Fortran source. Ordinarily I might suggest BIND(C,NAME="Fcode") but you have not coded your Fortran to be compatible with that so let's skip it.
Steven_L_Intel1
Look at the actual BuildLog.htm and examine the command line passed to LINK. Does it reference your library? I have sometimes seen where even adding the Fortran library as a dependent project doesn't cause the parent to link it in. I have never figured out a specific cause of this and it is rare enough that when I do encounter it I just add the library manually.
Of course, it's possible that the library is referenced and the symbols don't match.
Should the Fortran project resolve _WinMain@16?
kulachi
Much obliged Steve!
I spent another 3 hours but no success. Here is some more detail on this.
The source code:
C/C++:
#include
#include
#ifdef __cplusplus
extern "C"
#endif
void FCode(char *STR_OUT, size_t STR_OUT_LEN);
int main(int argc, char *argv[]) {
char String[] = "Hello";
FCode(String, sizeof(String));
Fortran:
SUBROUTINE FCode (String)
IMPLICIT NONE
CHARACTER(*), INTENT(IN) :: String
WRITE(*,*) String
END SUBROUTINE FCode
Now, I specifically added the LIB in C/C++Project > Properties > Additional Include Directories, and set C/C++Project > Properties > Linker > General > Show Progress to /VERBOSE. This gave me the following (rather lengthy) build log:
1>------ Build started: Project: Lib1, Configuration: Debug Win32 ------
1>Lib1.F90
1>
1>Build log written to "file://C:TCPIP_SRCLYetAnotherLib1DebugBuildLog.htm"
1>Lib1 - 0 error(s), 0 warning(s)
2>------ Build started: Project: YetAnother, Configuration: Debug Win32 ------
2>Compiling...
2>CC.cpp
2>Linking...
2>Starting pass 1
2>Processed /DEFAULTLIB:MSVCRTD
2>Processed /DEFAULTLIB:OLDNAMES
2>Searching libraries
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libkernel32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libuser32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libgdi32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libwinspool.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libcomdlg32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libadvapi32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libshell32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libole32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Liboleaut32.lib:
2> Searching C:Program FilesMicrosoft Platform SDK for Windows XP SP2Libuuid.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VCPlatformSDKlibodbc32.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VCPlatformSDKlibodbccp32.lib:
2> Searching ..lib1debuglib1.lib:
2> Searching C:Program FilesMicrosoft Visual Studio 8VClibMSVCRTD.lib:
2> Found __imp__printf
2> Referenced in CC.obj
2> Loaded MSVCRTD.lib(MSVCR80D.dll)
2> Found ___security_cookie
2> Loaded MSVCRTD.lib(gs_cookie.obj)
2> Found @__security_check_cookie@4
2> Loaded MSVCRTD.lib(secchk.obj)
2> Found @_RTC_CheckStackVars@8
2> Loaded MSVCRTD.lib(stack.obj)
2> Found __RTC_Shutdown
2> Loaded MSVCRTD.lib(init.obj)
2> Found _mainCRTStartup
2> Loaded MSVCRTD.lib(crtexe.obj)
2> Found __IMPORT_DESCRIPTOR_MSVCR80D
2> Referenced in MSVCRTD.lib(MSVCR80D.dll)
2> Found ___report_gsfailure
2> Referenced in MSVCRTD.lib(secchk.obj)
2> Loaded MSVCRTD.lib(gs_report.obj)
2> Found "void __cdecl _RTC_Failure(void *,int)" (?_RTC_Failure@@YAXPAXH@Z)
2> Referenced in MSVCRTD.lib(stack.obj)
2> Loaded MSVCRTD.lib(error.obj)
2> Found __RTC_SetErrorFuncW
2> Referenced in MSVCRTD.lib(init.obj)
2> Loaded MSVCRTD.lib(userapi.obj)
2> Found __CRT_RTC_INITW
2> Found __forceCRTManifest
2> Referenced in MSVCRTD.lib(crtexe.obj)
2> Loaded MSVCRTD.lib(crtmanifest.obj)
2> Found ___CxxSetUnhandledExceptionFilter
2> Loaded MSVCRTD.lib(unhandld.obj)
2> Found __imp___configthreadlocale
2> Found ___globallocalestatus
2> Loaded MSVCRTD.lib(xthdloc.obj)
2> Found __setdefaultprecision
2> Loaded MSVCRTD.lib(fp8.obj)
2> Found __imp____setusermatherr
2> Found __matherr
2> Loaded MSVCRTD.lib(merr.obj)
2> Found __setargv
2> Loaded MSVCRTD.lib(dllargv.obj)
2> Found __RTC_Initialize
2> Loaded MSVCRTD.lib(initsect.obj)
2> Found __adjust_fdiv
2> Loaded MSVCRTD.lib(adjustfd.obj)
2> Found __imp___adjust_fdiv
2> Found __commode
2> Loaded MSVCRTD.lib(xncommod.obj)
2> Found __imp____p__commode
2> Found __fmode
2> Loaded MSVCRTD.lib(xtxtmode.obj)
2> Found __imp____p__fmode
2> Found ___onexitbegin
2> Loaded MSVCRTD.lib(atonexit.obj)
2> Found __imp___encode_pointer
2> Referenced in MSVCRTD.lib(atonexit.obj)
2> Found __imp____set_app_type
2> Found __amsg_exit
2> Found __imp____getmainargs
2> Found __dowildcard
2> Loaded MSVCRTD.lib(wildcard.obj)
2> Found __newmode
2> Loaded MSVCRTD.lib(_newmode.obj)
2> Found ___security_init_cookie
2> Loaded MSVCRTD.lib(gs_support.obj)
2> Found __imp___exit
2> Found __XcptFilter
2> Found __imp___cexit
2> Found __imp__exit
2> Found __imp____initenv
2> Found __imp___CrtSetCheckCount
2> Found __IsNonwritableInCurrentImage
2> Loaded MSVCRTD.lib(pesect.obj)
2> Found __imp___CrtDbgReportW
2> Found __initterm
2> Found ___xc_a
2> Loaded MSVCRTD.lib(cinitexe.obj)
2>Processed /DEFAULTLIB:kernel32.lib
2> Processed /DISALLOWLIB:libc.lib
2> Processed /DISALLOWLIB:libcd.lib
2> Processed /DISALLOWLIB:libcmt.lib
2> Processed /DISALLOWLIB:libcmtd.lib
2> Processed /DISALLOWLIB:msvcrt.lib
2> Found __initterm_e
2> Found ___native_startup_state
2> Loaded MSVCRTD.lib(natstart.obj)
2> Found __except_handler4
2> Referenced in MSVCRTD.lib(error.obj)
2> Referenced in MSVCRTD.lib(pesect.obj)
2> Loaded MSVCRTD.lib(chandler4gs.obj)
2> Found __NULL_IMPORT_DESCRIPTOR
2> Found MSVCR80D_NULL_THUNK_DATA
2> Found __crt_debugger_hook
2> Referenced in MSVCRTD.lib(gs_report.obj)
2> Found "int __cdecl _RTC_GetSrcLine(unsigned char *,wchar_t *,unsigned long,int *,wchar_t *,unsigned long)" (?_RTC_GetSrcLine@@YAHPAEPA_WKPAH1K@Z)
2> Loaded MSVCRTD.lib(pdblkup.obj)
2> Found "void __cdecl terminate(void)" (?terminate@@YAXXZ)
2> Referenced in MSVCRTD.lib(unhandld.obj)
2> Found __controlfp_s
2> Referenced in MSVCRTD.lib(fp8.obj)
2> Found __invoke_watson
2> Found __unlock
2> Found ___dllonexit
2> Found __lock
2> Found __imp___onexit
2> Found __imp___decode_pointer
2> Found __except_handler4_common
2> Referenced in MSVCRTD.lib(chandler4gs.obj)
2> Searching C:Program FilesMicrosoft Visual Studio 8VClibOLDNAMES.lib:
2> Found __imp__InterlockedExchange@8
2> Loaded kernel32.lib(KERNEL32.dll)
2> Found __imp__Sleep@4
2> Found __imp__InterlockedCompareExchange@12
2> Found __imp__TerminateProcess@8
2> Found __imp__GetCurrentProcess@0
2> Found __imp__UnhandledExceptionFilter@4
2> Found __imp__SetUnhandledExceptionFilter@4
2> Found __imp__IsDebuggerPresent@0
2> Found __imp__RaiseException@16
2> Found __imp__DebugBreak@0
2> Found __imp__WideCharToMultiByte@32
2> Found __imp__MultiByteToWideChar@24
2> Found __imp__lstrlenA@4
2> Found __imp__GetProcAddress@8
2> Referenced in MSVCRTD.lib(pdblkup.obj)
2> Found __imp__LoadLibraryA@4
2> Found __imp__QueryPerformanceCounter@4
2> Referenced in MSVCRTD.lib(gs_support.obj)
2> Found __imp__GetTickCount@0
2> Found __imp__GetCurrentThreadId@0
2> Found __imp__GetCurrentProcessId@0
2> Found __imp__GetSystemTimeAsFileTime@4
2> Found __imp__HeapFree@12
2> Found __imp__HeapAlloc@12
2> Found __imp__GetProcessHeap@0
2> Found __imp__GetModuleFileNameW@12
2> Found __imp__VirtualQuery@12
2> Found __imp__FreeLibrary@4
2> Found __IMPORT_DESCRIPTOR_KERNEL32
2> Referenced in kernel32.lib(KERNEL32.dll)
2> Found KERNEL32_NULL_THUNK_DATA
2>Finished searching libraries
2>Finished pass 1
2> Found __load_config_used
2> Loaded MSVCRTD.lib(loadcfg.obj)
2>CC.obj : error LNK2019: unresolved external symbol _FCode referenced in function _main
2>C:TCPIP_SRCLYetAnotherDebugYetAnother.exe : fatal error LNK1120: 1 unresolved externals
2>Build log was saved at "file://c:TCPIP_SRCLYetAnotherYetAnotherDebugBuildLog.htm"
2>YetAnother - 2 error(s), 0 warning(s)
========== Build: 1 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Note that 2> Searching ..lib1debuglib1.lib: appears several times, but no Found word with it. Here is the Build Log for the C/C++ project:
Build Log:
Build started: Project: YetAnother, Configuration: Debug|Win32
Command Lines Creating temporary file "c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003747085136.rsp" with contents
/Od /I "C:TCPIP_SRCLYetAnotherLib1DebugLib1.lib" /D "_MBCS" /FD /EHsc /RTC1 /MDd /Fx /Fo"Debug" /Fd"Debugvc80.pdb" /W3 /c /Wp64 /TP .CC.cpp
Creating command line "cl.exe @c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003747085136.rsp /nologo /errorReport:prompt"
Creating temporary file "c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003847085136.rsp" with contents
/VERBOSE /OUT:"C:TCPIP_SRCLYetAnotherDebugYetAnother.exe" /INCREMENTAL:NO /LIBPATH:"C:TCPIP_SRCLYetAnotherLib1DebugLib1.lib" /MANIFEST /MANIFESTFILE:"DebugYetAnother.exe.intermediate.manifest" /DEBUG /PDB:"c:TCPIP_SRCLYetAnotherdebugYetAnother.pdb" /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "..lib1debuglib1.lib"
".DebugCC.obj"
Creating command line "link.exe @c:TCPIP_SRCLYetAnotherYetAnotherDebugRSP00003847085136.rsp /NOLOGO /ERRORREPORT:PROMPT"
Any ideas?
-Kulachi
Steven_L_Intel1
kulachi
I love you Steve!
