Mixed Language Example
Kipling__Michael
PREFACE: My solution includes C++ code calling routines from a C dll and a Fortran dll, with calls between the two dll's also.
1st question:
In the example code for using Fortran Modules in C, the variable A in the moduleis accessed with the C code:
extern float EXAMP_mp_A[3];
What is the "mp"? Why is it needed?
2nd question:
Is it necessary in the C code to import each needed variable in the module, or only import the module like this:
__declspec( dllimport ) EXAMP;
Mike
The _mp_ indicates that this is a module symbol - variable A in module EXAMP.
It is necessary to declare each variable separately. C doesn't know anything about Fortran modules.
Kipling__Michael
I have actually tried this, and it takes care of the unresolved external problem I was getting. In the Fortran dll I placed a line like:
!DEC$ ATTRIBUTES DLLEXPORT :: A
At the top of the C code I placed a line similiar to:
__declspec( dllimport ) EXAMP_mp_A;
In a function in the C code which is called by C++ code I set the value of A like this:
EXAMP_mp_A = 123.0;
(note: A is not an array in my code)
This C function then calls a Fortran subroutine from the Fortran dll. The Fortran subroutine uses the module which contains the variable A.
In the debugger in the C routine, I can see that A has been set to 123. However, when I step into the Fortran routine, the value of A = 0.
Mike
I just tried this by modifying the sample C_CALLS_Fortran and it worked fine. Here's what I did.
To project FDLL, I added a file mymod.f90 as follows:
module mymod
real A
end module mymod
I changed fsub.f90 as follows:
SUBROUTINE FSUB (INT_ARG, STR_IN, STR_OUT)
use mymod
IMPLICIT NONE
WRITE (INT_STR,'(I5.5)')INT_ARG + INT(A)
In project C_USEDLL I edited cmain.cpp to add these lines:
extern "C" __declspec( dllimport) float MYMOD_mp_A;
void main (int argc, char *argv[])
char instring[40];
char outstring[40];
int intarg;
strcpy(instring,"Testing...");
intarg = 123;
MYMOD_mp_A = 5.0;
I made sure that C_USEDLL was the Startup Project (right click on it and select "Set as startup project"), build and run. Stepping into FSUB I could see that A had the value 5 and it was used in the WRITE.
Kipling__Michael
Quoting - Mike K
EXAMP_mp_A = 123.0;
Mike
Kipling__Michael
I now have this code working correctly. The 2 things I learned since first asking the question are:
1. It is necessary to export each module variable which will be used by the C routine with something like this:
2. When importing into the C code, include the type of each variable (int, float, double) like:
__declspec(dllimport) double EXAMPL_mp_A;
Mike
