29653 Discussions
Mixed Language Programming: VB/Fortran
kps
I am working on a project with mixed language programming Visual Basic~Fortran. A .dll file (ZFact.DLL) is created from a Fortran source code with several Subroutines, Functions, and a Block Data group. Each of the Subroutines and Functions (but not the Block Data group) has the ATTRIBUTES Directive with the DLLEXPORT property declared as shown below:
!DEC$ ATTRIBUTES DLLEXPORT :: PARAMDL
!DEC$ ATTRIBUTES DLLEXPORT :: ZDETAIL
? etc.
The VB program declares the Fortran subroutines (in the .dll file) in the `declarations? section of its module as follows:
Declare Sub PARAMDL Lib "C:Program FilesMicrosoft Visual StudioVB98MyProjectsFacorFact.dll" (NCC As Integer, CID() As Integer)
Declare Sub CHARDL Lib "C:Program FilesMicrosoft Visual StudioVB98MyProjectsFacorFact.dll" (NCC As Integer, XI() As Double,ZB As Double, DB As Double)
? etc.
Yet, the VB program executes up to the point it makes the first call to a subroutine in the .dll file and then crashes with the following error message:
Run-time error ?53?:
File not found: C:Program FilesMicrosoft Visual
The .dll file (ZFact.dll) and the corresponding library file (ZFact.lib) are there in the same directory as specified above ? I have checked.
Any ideas or help from any one?
Just in case this has any relationship to the problem ? the call to subroutine in VB and the Subroutine declaration in Fortran along with data type declaration statements are given below:
VB Program:
Call PARAMDL(NCC, CID())
Public CID(1 To 21) As Integer, NCC As Integer
Fortran .dll File:
SUBROUTINE PARAMDL (NCC, CID)
INTEGER NCC, CID(21)
Is the entire array CID being passed on correctly from VB to Fortran?
Thanks!
Krishna Sinha
The "error 53" has nothing to do with the way you're calling the routine - it isn't getting that far. The error message is misleading - it can come up if your DLL depends on other DLLs that are not found. See http://www.compaq.com/fortran/kb/q1023.html for part of the solution, though another thing can be if you build a Debug configuration DLL and take it to a system where CVF isn't installed. The solution there is to build a Release configuration (and install the run-time DLLs as in the article.)
Steve
