Mixed languages
Giel_H_
Steve Lionel has modified the C_CALL_Fortran mixed language samplefrom CVF into an IVF sample.
The sample uses a FDLL project which builds the Fortran source of subroutine FSUBas a DLL. FSUB has an integer and a character string input argument and an character string output argument. FSUB concatenates the input arguments tooneoutput string.
A c/c++ main programUSEDLL calls the dll version of FSUB.
As an extension to this sample I am interested in ac/c++DLL project (say CDLL) in whichthe cdllsource codecontains (an entry of)a character function that calls the FSUB dll and returns thec string constructed by FSUB.
Is that possible?
Giel
Most anything is possible, but I don't fully understand your specification. How would you declare this C function in C? (Pretend Fortran isn't part of this.) What does it mean to be a "character function" in C?
Giel_H_
I admit that the use of "function" and "subroutine" is indeed confusing.
Iwould suggest anything like:
LPTSTR CFUN
LPSTR CFUN
char *CFUN
And for the definition of the function CFUN:
LPTSTR CFUN(int *int_arg,LPTSTR *str_in)
LPSTR CFUN(int *int_arg,LPSTR *str_in)
char *CFUN(int *int_arg, char *str_in)
The body of the latter CFUN wouldbe something like
char *str_out;
int STR_OUT_LEN;
STR_OUT_LEN= 512;
FSUB(&int_arg,str_in, str_out, strlen(str_in),STR_OUT_LEN);
return str_out;
Giel
Jugoslav_Dujic
Valued Contributor II
Uh-oh. You see, the problem with Fortran strings is that they-re two-fold: the passed information must always contain both the address and the length. Now, since both cannot be returned through registers, Fortran compiler "internally" turns the character-valued function into:
FUNCTION StrRet()
CHARACTER(10):: StrRet
StrRet="1234567890"
END FUNCTION StrRet
extern "C" char* strret(char*, int)
Well, maybe, I didn't care to do complete reverse-engineering. There are similar issues with functions returning TYPEs, arrays etc. So, it's better to avoid functions returning anything other than plain vanilla ints or floats in mixed-language programming.
Giel_H_
OK. Exactly, therefore I would like to usethe CFUN.
Giel
In C, your CFUN returns a pointer to a string, one that is presumably allocated within the function. You can do the same in Fortran. The equivalent Fortran function would be something like this:
function CFUN()
integer(int_ptr_kind()) :: CFUN
character(10) :: retstr = 'abcdefghij'
integer(1), dimension(*) :: temp
pointer (p, temp)
p = malloc (len(retstr)+1)
do i = 1,len(retstr)
temp(i) = ichar(retstr(i:i)
end do
temp(ubound(temp)) = 0
CFUN = P
return
end
It's then the caller's responsibility to deallocate the result.
