Modeless Dialog Create Fails
Brooks_Van_Horn
I constructed my RC file in Visual Studio 2013, but I developed my .f90 files outside of VS once they were created in VS as a fram for an SDI file. I am trying to create something like the Angle project with a dialog as the main window and perform graphics in the SDI framework. My dialog styles are exactly as the main dialog in Angle. The RC compiles my rc-file with no warnings or errors. I'm using:
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.110 Build 20150815
My build gives no warnings nor errors as:
g:\Desktop\Pearson>rc Pearson.rc
Microsoft (R) Windows (R) Resource Compiler Version 6.3.9600.17298
Copyright (C) Microsoft Corporation.  All rights reserved.
g:\Desktop\Pearson>rem ifort /nologo /c PearsonGlobals.f90
g:\Desktop\Pearson>ifort /nologo /WinApp Pearson.f90 MyLib.Lib Pearson.res
My code to startup the dialog looks like:
     bret = DlgInit( IDD_PMAIN, gDlg)
     If (bret == FALSE) Then
        ret = MessageBox(0, "DlgInit failed to launch IDD_PMAIN"C, "SetUpMyDlg"C, MB_OK)
        Call PostQuitMessage(999)
        return
     End If
     hDlg = gDlg%HWND
     hWndDlg = hDlg
     bret = DlgSetSub(gdlg, IDD_PMAIN, WinDlgSub)
     type *, 'SetUpMyDlg:: DlgSetSub(IDD_PMAIN) RC = ', bret
     bret = DlgSetSub(gDlg, IDC_FIT, DlgChanged)
     type *, 'SetUpMyDlg:: DlgSetSub(IDC_FIT) RC = ', bret
     bret = DlgSetSub(gDlg, IDC_SAMP, DlgChanged)
     type *, 'SetUpMyDlg:: DlgSetSub(IDC_SAMP) RC = ', bret
     bret = DlgSetSub (gDlg, IDC_PCTYPE, OnSpinEdit, DLG_LOSEFOCUS)
     type *, 'SetUpMyDlg:: DlgSetSub(IDC_IDC_PCTYPE) RC = ', bret
     bret = DlgModeless(gDlg, nCmdShow)
     type *, 'SetUpMyDlg:: DlgModeless RC = ', bret
        ret = MessageBox(0, "DlgModeless failed for IDD_PMAIN"C, "SetUpMyDlg"C, MB_OK)
        Call PostQuitMessage(998)
        return
     End If
My debug produces:
 SetUpMyDlg:: DlgSetSub(IDD_PMAIN) RC =  T
 SetUpMyDlg:: DlgSetSub(IDC_FIT) RC =  T
 SetUpMyDlg:: DlgSetSub(IDC_SAMP) RC =  T
 SetUpMyDlg:: DlgSetSub(IDM_EXIT) RC =  F
 SetUpMyDlg:: DlgSetSub(IDC_IDC_PCTYPE) RC =  T
 SetUpMyDlg:: DlgModeless RC =  F
And then I get the MessageBox notice. Can anyone help me?
Thanks, Brooks
mecej4
The debug output that you showed is not matched to the code that you showed. Specifically, there is no line of code among those shown that could have produced the output "SetUpMyDlg:: DlgSetSub(IDM_EXIT) RC =  F".
Brooks_Van_Horn
Yes, I had deleted that after I captured my debug output.
Sorry about that.
Brooks
andrew_4619
So after the dlg modeless call do you enter "WinDlgSub" with callbacktype =  DLG_INIT status?
Brooks_Van_Horn
don't know. No debug there.
However...Don't know what I did but it's working now. Thanks much for talking.
Brooks
dboggs
When you say "perform graphics in the SDI framework" what does that mean? Are you planning on coding your own graphics using primitive graphic functions, in IVF? If so that requires a "Quickwin" project type, and that would in turn imply an MDI framework, not SDI. But I know nothing about "the Angle project" so I may be completely off base here.
Angle is one of the Win32 samples. It doesn't use QuickWin.
