29647 Discussions
write(...,*) difference from G95. Bug?
Guthrie_M_
here is the test code:
      character(len=100)::buf
      write(buf,*)0.,'ABC'
      write(*,*)buf
      end
With intel (Composer XE 2015) the output is
 0.0000000E+00ABC
while with G95 it is
 0. ABC
Note the space with G95, which allows a subsequent read(...,*).
This seems like a bug to me.
Interesting. I see two problems here - the missing blank (which IS inserted if you write to a file), and the use of E format where the standard calls for F. I'm more than a bit astonished at this and will follow up with the developers. Thanks for reporting this.
Escalated as issue DPD200380295, The issue arises only when doing internal writes, which is perhaps why we haven't seen this reported long ago. I played around with this some and suspect that we are actually using G format for the reals, which would not be correct. While your test case doesn't show this, /standard-semantics implies /assume:noold_ldout_format which changes how a real zero is formatted. This changed between Fortran 95 and Fortran 2003, and our default behavior is consistent with F95. What is strange is that if you enable /assume:noold_ldout_format, the formatting of zero changes for external files but not internal files!
This will be fixed for a major release later this year.
