Module and shared data
gelarimer
Débutant
1 400 Visites
I would like to declare the arrays X, Y, DX, DY, and A in the shared data of theMODULE below, and eliminate the associated dummy arguements from Subroutine SplineSetup(). These arrays areused by Sub, Spline() in the same MODULE, but are not used outside the MODULE. However,the DIMENSION of the arraysis a variable 'N' which is a dummy arg for Sub. SplineSetup(), and this seems to prevent including the arrays in the MODULE's shared data. Is there a way to do this?
Thanks for any comments.
[plain]MODULE SplineFit
! shared data here
CONTAINS
SUBROUTINE SplineSetup(N,X,Y,DX,DY,A)
! code below is modified version of NA 300 piece wise cubic spline interpolation
! example code
! N -- number of data points
! X -- X(1:N) array or X input values to be used for interpolation
! Y -- Y(1:N) array or Y input values to be used for interpolation
! DX, DY, A coefficient arrays returned
IMPLICIT NONE
INTEGER N, N1
INTEGER ib
INTEGER i
REAL, DIMENSION(N) :: X, Y
REAL, DIMENSION(N) :: DX, DY, A
REAL, DIMENSION(N) :: T
REAL PIV
       A(1) = 0.0
       A(N) = 0.0
       N1 = N - 1
       do i = 1, N1
         DX(i) = X(i+1) - X(i)
         DY(i) = (Y(i+1) - Y(i))/DX(i)
       end do
       T(1) = 0.0
       do i = 2, N1
         PIV = 2.0*(DX(i-1)*DX(i)) - DX(i-1)*T(i-1)
         T(i) = DX(i)/PIV
         A(i) = (DY(i) - DY(i-1) - DX(i-1)*A(i-1))/PIV
       end do
       do ib = 2, N1
         i = N + 1 - ib
         A(i) = A(i) - T(i)*A(i+1)
       end do
!       iError = 1
       RETURN
END SUBROUTINE
SUBROUTINE Spline(N,XX,S)
! INPUT -- XX any value
! OUTPUT -- S = Spline evaluated at XX
INTEGER K
INTEGER N
REAL XX, S
REAL W, V
       K = 1
       ! lower bound
       do
         if(XX .LT. X(K)) then
           K = K-1
           if(K .EQ. 0) CYCLE
           K = 1
           S = Y(1) + (DY(1) - DX(1)*A(2))*(XX-X(1))
           RETURN
         end if
         ! if(XX .GE. X(K)) then EXIT do loop
         EXIT
       end do
       ! upper bound
       do
         if(XX .GE. X(K+1)) then
           K = K+1
           if(K .NE. N) CYCLE
           K = N - 1
           S = Y(N) + (DY(K) + DX(K)*A(K))*(XX-X(N))
           RETURN
         end if
         ! if(XX .LT. X(K+1)) then EXIT do loop
         EXIT
       end do
       W = (XX - X(K))/DX(K)
       V = 1.00 - W
       S = W*Y(K+1) + V*Y(K) + (DX(K)**2)*((W**3 - W)*A(K+1) + (V**3 - V)*A(K))
       RETURN
END SUBROUTINE
END MODULE[/plain]
0 Compliments
3 Réponses
Les_Neilson
Précieux contributeur II
1 400 Visites
Put the arrays before the contains and make them allocatable.
Module SplineFit
real, allocatable :: X(:)
real, allocatable :: Y(:)
real, allocatable :: DX(:)
real, allocatable :: DY(:)
real, allocatable :: A(:)
CONTAINS
Subroutine SplineSetup(N)
real T(N) ! Automatic local array
! remove the declarations for X,Y,DX,DY,A
! They will be available from host association
! Allocate the arrays.
! If you are calling this routine many times with different values of N you will need to
! deallocate any existing allocations.
! It is also a good idea to check for allocate errors as a precaution.
integer :: ierr
allocate(X(N),stat=ierr)
repeat for Y, DX, DY and A
remove the declarations of real X, Y DX, DY and A from Subroutine Spline, they will be available via host association once they have been allocated by SplineSetup
Les
0 Compliments
gelarimer
Débutant
1 400 Visites
Les, yourexplanation was easy to follow, thank you.
0 Compliments
tropfen
Nouveau contributeur I
1 400 Visites
if you want to keep the arrays only useable inside the module add ',private' in the declaration.
real, allocatable,private :: X(:)
Frank
0 Compliments
Répondre
