29652 Discussions
Module load in oneapi for coarray run
sverdrup
Hi all,
I'm triing to compile and run a fortran code with coarray. The compilation of the code seems ok, but when I run it I obtaine the seguent error:
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 721 RUNNING AT 41ca5757f459
= KILLED BY SIGNAL: 11 (Segmentation fault)
= RANK 1 PID 722 RUNNING AT 41ca5757f459
I've tried also hello world code with coarray but the resault is the same, not seem's to be a memory error! It is possible I have to load other modules?
This is my loaded modules:
Currently Loaded Modulefiles:
 1) mpi/2021.6.0   2) tbb/latest   3) compiler-rt/latest   4) oclfpga/latest   5) compiler/2022.1.0   6) init_opencl/2022.1.0   7) vtune/2022.2.0
and this is the list of the avalibles modules from oneapi modulefiles:
--------------------------------------------------------------- /opt/intel/oneapi/modulefiles ---------------------------------------------------------------
advisor/2022.1.0 compiler-rt32/latest dev-utilities/2021.6.0 dnnl/latest inspector/2022.1.0 mkl/latest vpl/2022.1.0
advisor/latest compiler/2022.1.0 dev-utilities/latest dpl/2021.7.0 inspector/latest mkl32/2022.1.0 vpl/latest
ccl/2021.6.0 compiler/latest dnnl-cpu-gomp/2022.1.0 dpl/latest intel_ipp_intel64/2021.6.0 mkl32/latest vtune/2022.2.0
ccl/latest compiler32/2022.1.0 dnnl-cpu-gomp/latest icc/2022.1.0 intel_ipp_intel64/latest mpi/2021.6.0 vtune/latest
clck/2021.6.0 compiler32/latest dnnl-cpu-iomp/2022.1.0 icc/latest intel_ippcp_intel64/2021.6.0 mpi/latest
clck/latest dal/2021.6.0 dnnl-cpu-iomp/latest icc32/2022.1.0 intel_ippcp_intel64/latest oclfpga/2022.1.0
compiler-rt/2022.1.0 dal/latest dnnl-cpu-tbb/2022.1.0 icc32/latest itac/2021.6.0 oclfpga/latest
compiler-rt/latest debugger/2021.6.0 dnnl-cpu-tbb/latest init_opencl/2022.1.0 itac/latest tbb/2021.6.0
compiler-rt32/2022.1.0 debugger/latest dnnl/2022.1.0 init_opencl/latest mkl/2022.1.0 tbb/latest
Thanks in advance,
best regards
Ron_Green
netCDF and hdf5 is kicking me around.  I've never found it easy to build those packages.  I tried to install with YUM but all I got was the libraries, no include or module file(s).
Ron_Green
I found hdf5-devel and netcdf-devel and netcdf-fortran-devel but these are for gfortran (sigh).  looks like I have to go back to source builds.
Which brings up a good question - you DO have netcdf-fortran and hdf5 built for INTEL FORTRAN?  You aren't trying to use those libs built for gfortran are you?
sverdrup
Hello Ron, sorry for the delay...
The the installation of the netcdf libraries for intel compilers are quite complicated. You have to compile the libraries and various dependencies with the intel fortran and c compilrs.
I've wrote a little bash script to download and compile all the libreries, I hope it will be useful to you.
 You will definitely have to change something, and in the end remember to export the paths of the libraries.
If you need help, do'nt hesitate, best regards,
a.
sverdrup
Ron_Green
I have it built and running to a certain point.  Seems it needs a data file in the /data directory??  Oh, and what OS distro and version are you running under?
Also, do this
ldd <executable>
my executable is named 'bathy' and has this:
ldd bathy
	linux-vdso.so.1 (0x00007fff961e0000)
	libnetcdff.so.7 => /cts/tools/library/netcdf4-intel-fortran/4.5.4/lib/libnetcdff.so.7 (0x00007f1d30b28000)
	libsz.so.2 => /cts/tools/library/szip/2.1.1/lib/libsz.so.2 (0x00007f1d30b13000)
	libicaf.so => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libicaf.so (0x00007f1d30aa5000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1d3092f000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1d3090c000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1d3071a000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f1d30dc2000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1d306ff000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f1d306f9000)
	libnetcdf.so.19 => /cts/tools/library/netcdf4-intel/4.9.0/lib/libnetcdf.so.19 (0x00007f1d304b8000)
	libhdf5_hl.so.200 => /cts/tools/library/hdf5/1.12.0/lib/libhdf5_hl.so.200 (0x00007f1d3048e000)
	libhdf5.so.200 => /cts/tools/library/hdf5/1.12.0/lib/libhdf5.so.200 (0x00007f1d2fe0b000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f1d2fdef000)
	libimf.so => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libimf.so (0x00007f1d2f761000)
	libifport.so.5 => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libifport.so.5 (0x00007f1d2f533000)
	libifcoremt.so.5 => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libifcoremt.so.5 (0x00007f1d2f393000)
	libsvml.so => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libsvml.so (0x00007f1d2d331000)
	libintlc.so.5 => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libintlc.so.5 (0x00007f1d2d0b9000)
	libmpi.so.12 => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/mpi/2021.6.0/lib/release/libmpi.so.12 (0x00007f1d2b871000)
	libirng.so => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libirng.so (0x00007f1d2b507000)
	libmpifort.so.12 => /nfs/pdx/disks/cts2/tools/oneapi/2022.2.0-up1/mpi/2021.6.0/lib/libmpifort.so.12 (0x00007f1d2b153000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1d2b149000)
Ron_Green
and try
export I_MPI_FABRICS=shm
and run on one node only
