29650 Discussions
Module procedures still invisible to navigation
Andrew_Smith
Valued Contributor I
Some changes appear with some blurry icons appearing now, but still doesn't recognise any subroutine or function with the keyword "MODULE".
Devorah_H_Intel
Is this a new issue specific to IFX, or was it reported previously on the forum or OSC? I will investigate it further.
andrew_4619
I am not sure I understand what you mean. When I look in a submodule in VS2022 with the latest Fortran, in the header pulldown on the right I see all the subroutines and functions irrespective if the have the module prefix. Is it some intermittent problem?
Andrew_Smith
It is not intermittent. Here is a reproducer: It gives an empty list:
submodule (Plant) Planted
contains
   module procedure a
   end
end submodule
 Whereas, redefining a as a subroutine does get picked up:
contains
   module subroutine a
   end
end submodule
andrew_4619
OK that isn't consistent with the description in the original post. I do confess to not understanding your usage case in the first code snippet I thought the valid usage of  "module procedure a" was only within an interface block relating to a subroutine with the contains. Anyway I have no useful comments to add.
Andrew_Smith
The interface to the module procedure would be declared in the module. The implementation in the submodule does not need to repeat the interface and can just be declared a MODULE PROCEDURE. This is normal practice for me as it is more productive (less typing). and less error prone. If Intel added a search for PROCEDURE as well as SUBROUTINE and FUNCTION, it could improve navigation immensely.
My code example was consistent with my original post.
andrew_4619
Ok ""still doesn't recognise any subroutine or function with the keyword "MODULE"." It does not recognise procedure with the keyword module. It does recognise module subroutine and module function. That is what I meant. [edited]
Devorah_H_Intel
Andrew_Smith
I don't think it is a new issue or specific to IFX. It may well have been reported previously but hard to search for
andrew_4619
I do not recall  seeing this reported before. Interestingly I opened one of my exiting submodules and added (in the contains)
   module procedure a
   end
It started the reparsing the file for syntax 'intellisense' or whatever it is called and VS promptly terminated. I reopened and repeated that a few time in slightly different ways with the same result!
However, having slept on it rebooted and tried again it does not crash so maybe VS was having a bad day.
