29653 Discussions
Nested SELECT TYPE and SELECT RANK constructs.
OP1
New Contributor III
I get an access violation error with ifort 2021.9.0 ... and an ICE with ifx 2023.1.0 with the following code.
MODULE M
IMPLICIT NONE (TYPE, EXTERNAL)
CONTAINS
    SUBROUTINE S(X)
    CLASS(*) :: X(..)
    SELECT RANK (X)
        RANK (0)
            SELECT TYPE (XX => X)
                TYPE IS (INTEGER)
                    WRITE(*, *) 'X is of type INTEGER.'
            END SELECT
    END SELECT
    END SUBROUTINE S
END MODULE M
PROGRAM P
USE M
INTEGER :: I
CALL S(I)
END PROGRAM P
Either there is a missing check in the compiler to prevent those nested constructs, or this is a legal code but there is a compiler bug.
FortranFan
The code appears conformant, it looks like a bug in IFORT.
Intel team: FYI, IFX encounters ICE with this.
Ron_Green
we will get a bug report open.  Thanks for sending this to us!
Ron_Green
bug ID is CMPLRLLVM-48814
Ron_Green
@OP1 this bug is fixed in the 2024.1.0 compiler.  I have just confirmed the fix in the released compiler.
riad_h_1
For Mac Os users who can't benefit from new releases (ifort no longer maintained...), does anyone have a workaround for this problem?
Devorah_H_Intel
This issue has been fixed in the recently released Intel Fortran Compiler, available for download as part of Intel HPC Toolkit 2024.2.1
