From a command line, I had a couple of scripts which did the following:
To compile:
gFortran -c %1.f95
Then to put each object and MOD into a static library:
ar r MyLib.a %1.o %1,mod
And finally to compile the main program, link it, and create an EXE
gfortran -o Test Test.f90 MyLib.a
I would like to do the same with iFort, xilink, etc. How do I accomplish this ? PS, I hate make so please don't suggest it.
Brooks Van Horn
Re LIB: Yes. Please read the LIB documentation before first use. In particular, the /out: option is needed to build a library from scratch. Once the library exists you can add .OBJ files to it.
Your configuration seems to have problems. I do not know why you are seeing all those messages from IPO. Until you get things going, I suggest the /Od option, which disables optimizations. You may have a number of options specified in IFORT.CFG.
s:\>cd lang s:\lang>ifort /c ranf.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.4.221 Build 20150407 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. s:\lang>
Did you see the line regarding the missing MSPDB110.dll?
链接已复制
Did you mean to post your topic on the Linux forum instead? https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x
"I hate make " - are you open to the idea of using an integrated development environment (IDE) instead? If yes, have you looked into Code::Blocks with Fortran plug-in (http://darmar.vgtu.lt/index.php) or Photran with Eclipse (http://www.eclipse.org/photran/)?
If you're moving to Windows OS, then consider Visual Studio from Microsoft.
The info I left and example were from a CMD window. I really like my UltraEd text editor and do not really like the VS editor unless I'm doing a GUI application. Microsoft would be wise to buy Ian's editor. I have been on Windows since version 3.11 but when I worked it was on a Unix system. By the time Microsoft reached Win 2K they took the lead over Unix and Win 7 is fae superior so no my poist was in the right forum. My only problem is with my lack of knowledge with the Intel Fortran Compiler and it's environment. I moved from GNU to Intel because gFortran had too many flaws -- like for instance EXIT in a do loop which correctly took me out of a do loop but also exited me the next time I tried to enter the loop. I've programmed in IBM Assembly, VB, VBS, C, C++ and Fortran over the years and I like Fortran the best.
So, please help me with using Intel tools that come with the Intel Fortran.
Thanks much,
Brooks Van Horn
The ar utility allows you to put anything into the mylib.a file, even the kitchen sink if you ask. The MS utility, lib.exe, on the other hand, will accept only .OBJ and .LIB files. MS command line syntax is a bit different from Unix shell syntax and the way to specify command line arguments is a bit different. The Intel Fortran documentation shows the Linux and Windows versions of options together, so you can do the translation easily.
For your example, you put commands such as the following into a .BAT file, and then invoke the batch file by just typing its name:
ifort /c %1.f90
lib mylib.lib %1.obj
ifort /Fetest test.obj mylib.lib
Note that you do not need to call the linker LINK.EXE directly unless you need to do some intricate things. The driver "ifort" calls LINK on your behalf, supplying the names of the Fortran runtime libraries needed automatically.
Hi mecej4,
Your approach looked promising but it has 2 problems: (1) lib doesn't create the file MyLib.lib and (2) iFort doesn't know what /c means. [See full transaction below]. The file ranf.f90 is a module with start and end looking like:
Module Random
Implicit None
Private
Integer(4),save:: a1(10) = (/ 36553, 54585, 26689, 23897, 3469, &
17497, 42849, 36333, 42433, 55809 /)
Integer(4),save:: a2(10) = (/ 10879, 27609, 17188, 43901, 18415, &
14220, 26925, 27616, 7319, 32133 /)
Integer(4),save:: a3(10) = (/ 46769, 65083, 27721, 12890, 50638, &
62024, 32833, 27512, 58086, 17276 /)
Integer(4),save:: rvals(3,10,100)
Character(len=200),save:: filename = 'RanF.bin'
Logical(4):: NoPass = .True.
Public:: RanFGet, RanFPut, RanF
Integer(4),save:: nsum(10,100)
Contains
bot = Dble( Ior( Ishft(a2(n),16), a1(n)) ) ! neg 16 ==> shift right pos ==> shift left
top = scale * Dble(a3(n))
x = top + bot
x = (x * normalize) + normalize
RanF = x
Return
End Function RanF
End Module Random
>>>>>>>>>>>>> Your attempt follows......
C:\Users\TCS\Desktop\Pearson>iFort /c ranf.f90
fortcom: Severe: No such file or directory
... file is '/c'
compilation aborted for /c (code 1)
Report from: Interprocedural optimizations [ipo]
INLINING OPTION VALUES:
-Qinline-factor: 100
-Qinline-min-size: 30
-Qinline-max-size: 230
-Qinline-max-total-size: 2000
-Qinline-max-per-routine: 10000
-Qinline-max-per-compile: 500000
Begin optimization report for: RANDOM.
INLINE REPORT: (RANDOM.) [1] C:\Users\TCS\Desktop\Pearson\ranf.f90(1,8)
warning #31001: The dll for reading and writing the pdb (for example, mspdb110.d
ll) could not be found on your path. This is usually a configuration error. Com
pilation will continue using /Z7 instead of /Zi, but expect a similar error when
you link your program.
Begin optimization report for: RANDOM::RANFGET
INLINE REPORT: (RANDOM::RANFGET) [2] C:\Users\TCS\Desktop\Pearson\ranf.f90(57,12
Begin optimization report for: RANDOM::RANFPUT
INLINE REPORT: (RANDOM::RANFPUT) [3] C:\Users\TCS\Desktop\Pearson\ranf.f90(79,12
INLINE REPORT: (RANDOM::RANF) [4] C:\Users\TCS\Desktop\Pearson\ranf.f90(112,23)
C:\Users\TCS\Desktop\Pearson>lib MyLib.lib ranf.obj
Microsoft (R) Library Manager Version 12.00.31101.0
Copyright (C) Microsoft Corporation. All rights reserved.
LINK : fatal error LNK1104: cannot open file 'MyLib.lib'
In principle, you have multiple choices available which resemble what you requested. As you used gfortran -O0, you should be happy with -Qipo- so that your .obj files will work even if renamed to .o. you may be able to use Microsoft mingw or cygwin static library tools. However, ifort Windows requires cl libraries, not gcc ones. It's difficult to see what might be easier when avoiding the beaten path with fort.
Hey Mercej4,
My first batch file contains:
del %1.mod %1.o
iFort /c %1.f90
lib MyLib.lib %1.obj
and the second one:
iFort /Test Test.obj MyLib.lib
test
When I did this under gFortran I had no errors and everything worked as expected.
MyLib.a had some 20 routines in it which were for two other main programs. I use it also as in this case to debug routines like RanF. ar with a prameter of ar creates an archive but I've not been able to find the parameter of lib used to create a library. That parameter for Lib is what started this whole question.
Brooks Van Horn
My bad.
ar cr libname
creates a library and
ar r libname objname
updates/adds objname to the library.
Hey All,
Got my problem solved!!!
Thanks to all!
Brooks
To create a library:
lib /def /out:MyLib.lib
lib /remove:MyLib.dll MyLib.lib
To list entries:
lib /list MyLib.Lib
To remove an obj file
lib /remove:some.obj MyLib.Lib
To add some coeff object to the library
lib MyLib.lib some.obj
Now a batch file to compile and add to MyLib.lib
iFort -O3 /c %1.f90
Then to link and run a batch file would have
ifort -o %1 MyLib.lib
