Multi Processor
truelies
Does Intel Fortran Composer XE 2011 for Windows support multi processor? What should I do to modify a code to support multi processor? Thanks.
Yes, it does. There are many ways to take advantage of multiprocessors. The simplest is adding the /Qparallel option, but by itself, it may not get you a lot. The Guided Auto Parallelization feature can help you with suggestions for code changes that improve autoparallelization. The DO CONCURRENT construct also works with /Qparallel.
Then there is OpenMP, which requires code changes. There is a large aection of the "Optimizing Applications" documentation dealing with parallelization.
There is also the Coarray feature from Fortran 2008, which supports multiprocessors by default, but requires the most code changes.
truelies
Thanks Steve. Do you have a document on those?
Found it: http://software.intel.com/sites/products/documentation/hpc/compilerpro/en-us/cpp/win/compiler_c/optaps/common/optaps_intro.htm?wapkw=%28Optimizing+Applications%29
but this one is for Intel C++, anything for Intel Fortran?
Wendy_Doerner__Intel
Valued Contributor I
All of the advice and switches in this article apply to Fortran also.
Wendy
Attaching or including files in a post
You can read the Fortran documentation here, if you don't have the product installed.
truelies
Steve,
I can't find anyone for multi processor, could you tell me which one? Thanks
All our products apply to mulit processor. The document which focuses on the Fortran Windows Compiler is here:
http://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/fortran/win/index.htm
Wendy
truelies
This link includes all fortran documents. I can see
and
Creating Parallel Applications
Which one is for how to change a code to multi processor in Intel Fortran? Thanks.
The "Creating Parallel Applications" link is more relevant. The "Optimizing" link is for general optimization topics.
