Mysterious warning message?
WSinc
I was trying to use this "optional" argument, but when I have all three arguments,
I get an error message #8055. Just a warning, but why doesn't the compiler accept it?
As far as I can tell, the code runs OK with or without the 3rd argument.
IDZ_A_Intel
I get no errors when compiling this source (after supplying a definition for CHUNK.)
TimP
If I comment out the include file, which you didn't supply, the only error is on account of undefined and uninitialized variable CHUNK.
WSinc
Even when you use the "compile" option under build?
Just pressing F5 only displays errors, not the warning #8055 message.
Would it be the interaction with other modules that triggers this?
Like I said, it's no biggie, but I'm wondering what the cause might be.
BTW, "chunk" was a parameter. It's value is 1000000.
IDZ_A_Intel
All you gave was one source file, so it really doesn't matter how it is compiled. There is clearly more context needed. Can you reproduce this in a new project or an independent directory?
WSinc
OK, here is the "whole caboodle."
There are two folders involved, because I tried to rebuild the project from scratch,
and it would not let me go back to the original folder name. I had to change the name of the project.
Anyway, you can reproduce the error by looking at the BUILDLOG.HTM, or by trying to recompile
the main program. Just pressing F5 only gives you errors, not warnings, so I had to use
"compile" under BUILD.
I was wondering if we can get a utility that will make it easier to rebuild the whole project from
just the source files.
IDZ_A_Intel
Something went wrong and your file did not upload (or download) correctly. Please try it again.
I find it pretty simple to add all the source files in one go.
WSinc
Ok, here it is again -
Apparently I cannot upload more than one file at a time.
I tried putting them both in one upload folder, it wouldn't take it for some reason.
So I could not put the two sets of file folders in two different archives.
So here is one archive with both folders in it.
IDZ_A_Intel
The complete text of the diagnostic is:
warning #8055: The procedure has a dummy argument that has the ALLOCATABLE, ASYNCHRONOUS, OPTIONAL, POINTER, TARGET, VALUE or VOLATILE attribute. Required explicit interface is missing from original source. [CHK]
I'm not sure how this message could be any clearer. The procedure you are calling, extprin, declares its third argument CHK as OPTIONAL. This requires that an explicit interface to extprin be visible in the caller, but there is none. The compiler's "generated interface checking" identified this inconsistency and correctly warned you about it.
If you want the CHK argument to be optional, then what I would recommend is to put extprin in a module and USE the module wherever you want to call it.
For more information, see these two articles I wrote on the topic:
Doctor Fortran and the Virtues of Omission
Doctor Fortran Gets Explicit!
Also, I assume you saw the warning about this line:
integer(4) ONE(0:10)/1,1,8*0/,nbit
where the compiler warned you that ONE(0:10) has more elements (11) than values you supplied (10).
