NAMELIST
brunocalado
[cpp]REAL (KIND=8), ALLOCATABLE	:: A(:)
REAL (KIND=8), ALLOCATABLE	:: B(:)
NAMELIST /vars/ A, B
[/cpp]
I'm trying to read a file with A and B, but when I read a get the folowing message:
forrtl: severe (18): too many values for NAMELIST variable, unit 11, file /test,
How can I use NAMELIST to read allocatable arrays?
My guess is that you did not allocate the arrays first. If you are expecting a NAMELIST read to do the allocation, you are mistaken.
C:Projects>type t.f90
REAL(8), ALLOCATABLE, DIMENSION(:) :: A,B
NAMELIST /vars/ A,B
ALLOCATE (A(2), B(3))
A = 1.0
B = 2.0
READ (*,vars)
WRITE (*, vars)
END
C:Projects> ifort /nologo t.f90
C:Projects t.exe
&vars A = 4,B = 5,6 /
&VARS
A = 4.00000000000000 , 1.00000000000000 ,
B = 5.00000000000000 , 6.00000000000000 , 2.00000000000000
You will need the latest 11.1 for this, as some earlier versions did not allow ALLOCATABLE arrays in NAMELIST at all.
TimP
With no example of your source code or data file, it is nearly pointless to attempt an answer. From the fragment you have shown, I would say don't try non-standard extensions until you have it working with a standard-compliant example.
NAMELIST /vars/ A,B
A = 1.0
B = 2.0
READ (*,vars)
WRITE (*, vars)
END
C:Projects t.exe
&VARS
