Name the .exe file
gsfantos
Hi to everyone,
is there any way that you could name the .exe file that is created by the compiler, by a name that you specify inside the source code?
Any ideas?
Thanks in advance guys
No. The name of the executable is determined completely by what is on the command line - either the name of the first input file or the value to /out or /Fe. Nothing inside the source file can change that.
