29238 Discussions
qustion about compilation and linking
davidqusx
fortran codes.
new System:IA-32-based system with Intel extended Memory64Technology (Intel EM64T)
old system: IA-32-based system
ifort -pc80 -prec-div -mp -shared -w -c -O3
ld -shared -o libdisl.so $(OBJECTS)
On the old system, everything is fine. However, when I make on the new system, the following warnings and errors generated:
ld: warning: i386 architecture of input file `disl_field.o' is incompatible with i386:x86-64 output
disl_field.o(.text+0x26): In function `disl_displ_':
: undefined reference to `for_cpystr'
Please help me find the problem with compilation and linking.
David
TimP
If you are running the 64-bit system, the default ld is the 64-bit one. It looks like you chose the 32-bit ifort. If you used the 32-bit ifort also for linking, it would choose a 32-bit ld and link against the 32-bit ifort runtime libraries. When you invoke ld directly, it's your responsibility to choose the ld which matches your .o files and to specify the Fortran libraries.
davidqusx
Please how tochoose 32- or 64- ifort/ld?
When you install the compiler, you have to choose a "custom" install to select the 32-bit compiler. I'm not sure how to tell it to use the 32-bit tools, offhand.
The 32 and 64 bit compilers are installed in different directories. The 32 bit is in /fc and the 64 bit in /fce. So you choose which one you want when you give the "source" command.
Message Edited by Steve_Lionel on 03-31-2006 08:46 AM
