Namelist and Arrays
Dishaw__Jim
According to the documentation and the compiler error messages, allocatable arrays and static arrays with nonconstant bounds cannot be used with a NAMELIST. For example,
REAL :: arr(gMax)
NAMELIST /NLIST/ arr
results in the error
Error: A NAMELIST group object must not be an array with nonconstant bounds.
This seems to be an arbitrary limit--is there a basis for it? I guess the only work around is to make the array large enough for the expected range of values for gMax.
The restriction is stated in the Fortran 95 standard, but in Fortran 2003 the rule is simply that the object cannot be an assumed-size array, so eventually we'll relax the implementation to meet the standard.
