Namelist and length type parameters
IanH
When it comes to namelist, I certainly don't know what I am doing.  But at least the compiler is with me in being confused.
PROGRAM p20151006_namelist
  IMPLICIT NONE
  TYPE :: t(len)
    INTEGER, LEN :: len
    REAL :: array(len)
  END TYPE t
  TYPE(t(:)), ALLOCATABLE :: a
  NAMELIST /nml/ a
  INTEGER, PARAMETER :: unit = 10
  CHARACTER(*), PARAMETER :: len_fmt = "(I10)"
  CHARACTER(*), PARAMETER :: filename = '2015-10-06 namelist.txt'
  INTEGER :: l
  ALLOCATE(t(5) :: a)
  a%array = [(REAL(l), l = 1, a%len)]
  PRINT "(I10,*(F4.1,:,1X))", a%len, a
  OPEN(unit, FILE=filename, ACTION='WRITE', STATUS='REPLACE')
  WRITE (unit, len_fmt) a%len
  WRITE (unit, nml)
  CLOSE(unit)
  DEALLOCATE(a)
  OPEN(unit, FILE=filename, ACTION='READ', STATUS='OLD', POSITION='REWIND')
  READ(unit, len_fmt) l
  ALLOCATE(t(l) :: a)
  READ (unit, nml)
  CLOSE(unit)
END PROGRAM p20151006_namelist
>ifort /check:all /warn:all /standard-semantics /stand:f08 "2015-10-06 namelist.f90"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
0_1855
U:\projects\FortranMisc\2015\2015-10-06 namelist.f90(20): catastrophic error: **Internal compiler error: internal abort*
* Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for 2015-10-06 namelist.f90 (code 1)
This variant, where the value of the derived type parameter is set by specification, compiles, but I am suspicious of the namelist output (and the PRINT statement output to the console?) - there are entries for the length parameter, noting that length parameters are not components. Plus the array values in the namelist output are bonkers.
PROGRAM p20151006_namelist2
  IMPLICIT NONE
  TYPE :: t(len)
    INTEGER, LEN :: len
    REAL :: array(len)
  END TYPE t
  CALL execute
CONTAINS
  SUBROUTINE execute
    CHARACTER(*), PARAMETER :: filename = '2015-10-06 namelist2.txt'
    INTEGER :: l
    ALLOCATE(t(5) :: a)
    CALL write(unit, a%len, a)
    CLOSE(unit)
    DEALLOCATE(a)
!    OPEN(unit, FILE=filename, ACTION='READ', STATUS='OLD', POSITION='REWIND')
!    READ(unit, len_fmt) l
!    ALLOCATE(t(l) :: a)
!    CLOSE(unit)
!    PRINT "(I10,*(F4.1,:,1X))", a%len, a
  END SUBROUTINE execute
  SUBROUTINE read(unit, l, a)
    INTEGER, INTENT(IN) :: unit
    INTEGER, INTENT(IN) :: l
    TYPE(t(l)), INTENT(OUT) :: a
    NAMELIST /nml/ a
    READ (unit, nml)
  END SUBROUTINE read
  SUBROUTINE write(unit, l, a)
    TYPE(t(l)), INTENT(IN) :: a
    NAMELIST /nml/ a
    WRITE (unit, nml)
  END SUBROUTINE write
END PROGRAM p20151006_namelist2
>ifort /check:all /warn:all /standard-semantics /stand:f08 "2015-10-06 namelist2.f90" && "2015-10-06 namelist2.exe" && type "2015-10-06 namelist2.txt"
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
"-out:2015-10-06 namelist2.exe"
-subsystem:console
"2015-10-06 namelist2.obj"
         5 1.0  2.0  3.0  4.0  5.0
         5
 &NML
 A%LEN     = 5,
 A%ARRAY   = 2.9511794E-39  , 0.000000       , 5.6051939E-45  , 2*0.000000
Kevin_D_Intel
Thank you IanH for reporting the issues.
Updated 11/19/2015: Submitted to Development
(Internal tracking id: DPD200378942 - internal error w/Namelist and length type parameters)
(Internal tracking id: DPD200378943 - incorrect results w/Namelist and length type parameters)
