Namelist with pointers
abhimodak
Hi
The snippet below compiles ok but throws an access violation when reading the namlist. I am using IVF 11.1.051 on VS2005 and WinXP64.
If P and T are not pointers, this error does not happen. The same is true for array X.
The access violation happens in debug mode while in release mode the values of P and T are stomped over. It runs fine when using XLFortran. If I have not done something silly here, may be there is a bug in the namelist implementation. (I know there is one with allocatable characters.)
Abhi
Module EMG
Implicit None
Private
Integer, Parameter :: rKind = kind(1.0d0)
! Define field
Type, Public :: newField
Real(rKind) :: E
Real(rKind) :: B
Real(rKind), Allocatable :: X(:)
End Type newField
Type(newField) :: Gauss
Target :: Gauss
! Entities that are public
Public :: rKind
Public :: Gauss
Public :: EMG_Initialize
Contains
Subroutine EMG_Initialize(KK, iError)
Implicit None
Integer, Intent(IN) :: KK
Integer, Intent(OUT) :: iError
iError = 0
! Allocate memory for the field
Allocate(Gauss%X(KK), stat=iError)
if (iError /= 0) then
iError = 1
endif
End Subroutine EMG_Initialize
End Module EMG
Program Test_NameList
Use EMG
Implicit None
Integer, Parameter :: LINP = 90, LOUT = 91
Integer :: KK, iError, ial
!Real(rKind) :: P, T
Real(rKind), Pointer :: P, T
!Real(rKind), Pointer :: X(:)
Logical :: Apply
NameList / INPUT/ Apply, P, T, X
KK = 3
! Initialize EMG
Call EMG_Initialize(KK, iError)
Write(*,*) "Error initializing EMG."
Stop
endif
NullifY(P)
P => Gauss%E
NullifY(T)
T => Gauss%B
!Nullify(X)
!X => Gauss%X
Allocate(X(KK), stat=ial)
if (ial /= 0) then
Write(*,*) "Allocation failed."
Stop
endif
Open(Linp, File="FieldCondition.inp", Form="Formatted", Status="Old")
Rewind(Linp)
Read(Linp, NML=INPUT)
Close(Linp)
Write(*,NML=INPUT)
End Program Test_NameList
The contents of file 'FieldCondition.inp' are:
&INPUT
Apply = F
P = 10.00000000
T = 1600.00000000
X = 6.603199904580657E-002,3.674703942511635E-004,2.807054850067047E-006
Sigh - we fixed a case for pointer arrays (coming in Update 4) but somehow overlooked pointer scalars. The new issue ID is DPD200142385.
abhimodak
Hi Steve
Just curious: Is update 4 going to include allowing allocatable characters in namelist?
I reported it here: http://software.intel.com/en-us/forums/showthread.php?t=69103
Abhi
Yes, that should work in update 4.
The fix for the issue in this thread should appear in Update 5, scheduled for late January.
abhimodak
FYI:
It looks like the namelist with pointers is working in update 5!
Abhi
