[fortran]module test_mod CONTAINS !> \brief Returns a pointer to the function described by the text string FUNCTION FIND_INTERPOLATION_FUNCTION(DESCRIPTION) IMPLICIT NONE ! Arguments CHARACTER(LEN=24), INTENT(IN) :: DESCRIPTION ! Result PROCEDURE(INTERPOLATION_FUNCTION), POINTER :: FIND_INTERPOLATION_FUNCTION ! Private variables ! Start work END FUNCTION FIND_INTERPOLATION_FUNCTION end module test_mod program hello use test_mod implicit none end program hello[/fortran]
The above code is not valid (because the abstract interface declaration of INTERPOLATION_FUNCTION is missing), so I'd expect ifort to throw an error. Instead, I get an ICE:
[bash]% ifort -c helloworld.f90
: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for helloworld.f90 (code 3)
% ifort --version
ifort (IFORT) 11.1 20091130
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.[/bash]
This is an interesting issue. After consulting with members of the Fortran standards committee, we find that the current standard (and the draft of F2008) is ambiguous and contradictory regarding the ability to declare a function result variable as a procedure pointer.
What we will be doing for now is to make this an error, until the standards committee decides how it should be handled. A workaround is to return a derived type containing a procedure pointer.
Thanks for looking into this & suggesting a workaround.
Returning a procedure pointer came naturally to me once I started getting used to abstract interfaces :), I can live with wrapping it in a derived type though, so... thanks!
