Naming trouble
Emil_S_
Hi The following code does not compile with ifort 14.0.3, but compiles and works fine with gfortran(4.6, 4.7 and 4.8).
module ab_mod
  type :: a
   contains
     procedure :: proc1
     procedure :: proc2
     generic :: proc => proc1, proc2
  end type a
  type :: b
     class(a), pointer :: a
  end type b
contains
  subroutine proc1(this, val)
    implicit none
    class(a) :: this
    integer, intent(out) :: val
    val=1
  end subroutine proc1
  subroutine proc2(this, val)
    implicit none
    class(a) :: this
    real, intent(out) :: val
    val=1.0
  end subroutine proc2
end module ab_mod
program test
  use ab_mod
  type(a), target :: a_obj
  type(b) :: b_obj
  integer :: val
  b_obj%a => a_obj
  call a_obj%proc(val)
  print *, val
  call b_obj%a%proc(val)
  print *, val
  call b_obj%a%proc1(val)
  print *, val
end program test
Ifort complains that
test.f90(40): error #8486: There is no matching specific subroutine for this type bound generic subroutine call.   [PROC]
compilation aborted for test.f90 (code 1)
The problem centers around the naming of the class(a) component of type b. If I change type b to
type :: b
class(a), pointer :: a_obj
end type b
and make the necessary changes to the program-section, the code compiles and runs fine with ifort. The question is, is it illegal to use the original naming? If so, why does ifort not complain a line 10? And why does it complain at line 40, and not 42?
Best regards
Emil Sørensen
FortranFan
Clearly a bug.  It exists in my Ifort 15 beta version too.  But I'm surprised to see this error because I do make use of a somewhat similar construct in one of my codes and it seems to work ok there.
Thanks, we'll take a look. This one sounds familiar...
This has been escalated as issue DPD200256512. It's legal to have the original code with the names being the same - type names and component names are in different "classes" of local names. Thanks for the nice example.
Emil_S_
All right, thank you for your responses. I'm just glad I could help.
This has been fixed for the 15.0 release later this year.
