Error #6005
alanlodge
I'm compiling existing code on IVF 11.1, and I'm getting lots of #6005 errors (A derived type object in a COMMON block shall not have default initialization) which I don't understand. The relevant structure is STRUCTURE /LOCAL_POINT/
CHARACTER*(16) TAG
INTEGER*4 BASEADD(3) /0,0,0/
BYTE TYPE /14/
END STRUCTURE
Is this because TAG doesn't have an initialiser? What should such an initialiser look like? Sorry - it's been years since I did any serious FORTRAN...
There are two fields of the structure that are initialized - given initial values. BASEADD has /0,0,0/ and TYPE has /14/. The problem is caused by the initialization and putting a record with initialized structure in a COMMON. The Fortran standard prohibits this, but I think that old DEC compilers allowed it. Of course, the standard doesn't have STRUCTURE/RECORD, but we generally try to keep STRUCTURE/RECORD and derived types as equivalent as we can. Any initialization of COMMON should be in a BLOCK DATA subprogram, however.
The following works:
[plain]BLOCK DATA
CHARACTER*(16) TAG
BYTE TYPE
END STRUCTURE
RECORD /LOCAL_POINT/ eN2B15S23
COMMON /MYC/ eN2B15S23
data eN2B15S23 /LOCAL_POINT('',[0,0,0],14)/
end[/plain]
Ideally, the STRUCTURE, variable and COMMON declarations would come from an INCLUDE file. Elsewhere in the program you'd just use the INCLUDE.
I will admit that I am a bit puzzled by this error and perhaps this should be a standards warning rather than an error. I will investigate.
rogcar
Hello there
Could give some more info? Using only this piece of code, I couldn't reproduce your error, as it worked flawlessly. Also, the inicializationis just fine. Is your structure inside any type definition, module, or whatever?
Roger
alanlodge
Quoting - rogcar
Hello there
Roger
Hi!
The variable I create appears in a common block, which is giving the problem. Here's all I need to reproduce the error:
PROGRAM TEST
CHARACTER*(16) TAG
BYTE TYPE /14/
END STRUCTURE
END PROGRAM
Any help would be appreciated!
[plain]BLOCK DATA
CHARACTER*(16) TAG
BYTE TYPE
END STRUCTURE
end[/plain]
alanlodge
Steve, that's what I needed! Thank you!
Eric_Luth
I'm running into this same problem in Intel Parallel Sutdio XE 2011 (version 12.0). The workaround suggested does work, but I'm not excited about fixing the 1000+ places were our legacy code has used this incorrect definition. You said "I will admit that I am a bit puzzled by this error and perhaps this should be a standards warning rather than an error. I will investigate." Is there a way to reduce this error to a warning?
Are there really 1000+ places where this is written, or do you use INCLUDE files to declare the type and/or the COMMON? If INCLUDE is not used, maintaining this application would seem to be a nightmare even without this issue. I'd hope that INCLUDE was used in which case it should be straightforward to move the initialization to a BLOCK DATA subprogram.
There is no way to prevent this diagnostic from aborting the compilation.
Valentin_P_2
I am migrating Compaq Visual Fortran code to Intel Visual Fortran.
The code has a derived-type array pointer in COMMON block and that creates the same problem.
Error #6005: A derived type object in a COMMON block shall not have default initialization [ XYplots ]:
is given for the following code:
MODULE test
TYPE Axis
     SEQUENCE
       integer:: parm = 1
END TYPE Axis
TYPE XYplotsData
     SEQUENCE
      real, pointer:: plot(:)
     TYPE (Axis):: X_axis
END TYPE XYplotsData
TYPE (XYplotsData), pointer::    XYplots (: )
COMMON /data1/  XYplots
END MODULE
There are no compilation errors if default initialization parm = 1 is taken off.
In the real (not simplified) code structure 'Axis' has many elements that have default initializations and I would like to keep it that way.
How do I define correctly this common block while keeping default initialization in Axis definition?
Take out the COMMON declaration. You don't need it for module variables.
