29284 Discussions
National Language Support (i.e., nls or dfnls.lib) library
matt_cunningham
Is there a National Language Support (i.e., nls or dfnls.lib) library available. I have Compaq legacy projects that cannot link because the projects reference 'dfnls.lib', and it cannot be found.
I assume you are using Intel Visual Fortran? You should rebuild your code that references the NLS routines. The support is provided in module IFNLS (DFNLS will work) - the implementation is in libifport.lib, I think - this is linked in by default.
