Could you provide me the ECCN and CCATS numbers for the Intel Fortran 9.0 Compiler (Windows). Thanks.
ECCN is 5D992. There is no CCATS number as the product does not contain encryption.
Quoting - Steve Lionel (Intel)
1) What is the ECCN classification for Intel Fortran Runtime Libraries Version 10.1 for IA-32?
2) Does Intel Fortran Runtime Libraries Version 10.1 for IA-32 contain or make calls to any cryptographic routines? (please note that in the case of making calls to cryptographic routines, it is not material whether you ship the cryptographic code (e.g. JCE or SSL) with your product or not, only if you are making calls to it)
If you answered "yes" to the question above, are you using the encryption for
a) data encryption
b) password protection, authentication, digital signatures, fixed data compression, hashing
Thank You
Kevin
There is no separate ECCN for the Fortran run-time libraries. There are no cryptographic routines or calls in it.
