29252 Discussions
Need earlier version of Intel® Fortran Compiler
Ema2
I need to get Intel Fortran Compiler for doing simulation in Aspen Plus v11, but the Aspen Plus software only works with the Fortran Compiler version that is earlier than 2025. Here https://www.intel.com/content/www/us/en/developer/tools/oneapi/fortran-compiler-download.html I found that the only Fortran Compiler offered by Intel is the 2025 version. Could you suggest me what to do with my current issue?
Your help is very much appreciated!
Ema2
Hello @andrew_4619. Many thanks for your reply. Having read the link you sent, I believe that it only works for Fortran Compiler with the version of 2024 or earlier than that. While, the 2025 version of Fortran Compiler has been released by Intel on 11 December 2024; and so far it seems that the config64.cfg file provided by Aspen Plus does not work for the 2025 version.
andrew_4619
The only difference will be some file paths in the scripts. Ask on an aspen forum would make more sense.
