28593 Discussions
Need help, accessing module data stored in Fortran dll from C++ 6
m_singh
Can experts and gurus guide me on this issue.
I am trying to share some data between the a VC++ program and a V Fortran dll. The data is declared in a module within the Fortran dll. The intent is that the main C++ program would fill in the data and call the Fortran dll, which will use that data and perform some analysis.
I used the dllexport directive for the variables in the module. But in my calling VC++ program I can not get access to the variables (unresolved external symbol).
Is this possible to do. Here is the relevent code. Can you give any pointers...
! Fortran dll
module mymodule
!DEC$ ATTRIBUTES DLLEXPORT::a
real a;
end module mymodule
subroutine FORTRANDLL
!DEC$ ATTRIBUTES DLLEXPORT::FORTRANDLL
use mymodule
end subroutine FORTRANDLL
! Main VC++ Calling program
// the moduledata.h file
extern "C" void __stdcall FORTRANDLL();
extern "C" float mymodule_mp_a,
// here is the calling function
void CMainFrame::OnToolsDosomething()
// *** the following code does not compile ***
mymodule_mp_a = 3.0f;
//******* Calling the fortran dll, this works
FORTRANDLL();
Mandeep
digger
At first try to view how name of your variable seen in dll, use for that Dependency Walker utility.
If you want to use C name convention, name of variable must seen like '_varname'. I don't know what kind of names use your fortran project, but you may to transform name using ATTRIBUTES directive.
For example:
real module_var_a
!DEC$ ATTRIBUTES C, DLLEXPORT :: module_var_a
or
real module_var_a
!DEC$ ATTRIBUTES ALIAS:'_module_var_a', DLLEXPORT :: module_var_a
And last thing, name of variable in c code must be the same like name in fortran code (or if you using ALIAS like name exported from DLL).
m_singh
You have a good point, I tried your idea, but still get an unresolved external.
module MYMODULE
real a;
!DEC$ ATTRIBUTES ALIAS:'_MYMODULE_mp_A', DLLEXPORT::a
end module MYMODULE
extern "C" float MYMODULE_mp_A ;
void Dosomething()
MYMODULE_mp_A = 3.0f;
I used Depends.exe and saw that this variable is exported out as '_MYMODULE_mp_A', runing DUMPBIN on the dll, with /exports also confirms that.
I even opened the Lib file for this dll in a text editor and saw this variable in there. So, it is being exported out from the dll, but the calling program can not find it.
Any ideas will be appreciated.
Mandeep
Get rid of the ALIAS in the Fortran code - you don't need it. I think you need a __pragma(dllimport) on the C declaration and to link against the export library created when the DLL was linked. Also, be sure you are using CVF 6.6B.
Steve
m_singh
I modified the C declaration to,
extern "C" float __declspec(dllimport) MYMODULE_mp_A;
then all worked.
Thanks to digger and Steve
Mandeep
