29641 Discussions
Need the Interface for Win32 MessageBoxTimeout
MikeWinsteps
Hi Folks, this looks a simple challenge, but can't get it to work. Here is my effort for 64-bit IFORT, but it doesn't work. Any suggestions?
INTERFACE
FUNCTION MessageBoxTimeOut( &
hWnd, &
lpText, &
lpCaption, &
uType, &
wLanguageId, &
dwMilliseconds )
use ifwinty
integer(SINT) :: MessageBoxTimeOut ! int
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'MessageBoxTimeOutA' :: MessageBoxTimeOut
integer(8) hWnd ! HWND hWnd
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpText
character*(*) lpText ! LPCSTR lpText
!DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: lpCaption
character*(*) lpCaption ! LPCSTR lpCaption
integer(UINT) uType ! UINT uType
INTEGER*2 wLanguageId
INTEGER*4 dwMilliseconds
END FUNCTION
END INTERFACE
GVautier
New Contributor III
Hello
This is an undocumented function.
It is identical to the MessageBox API definition except it has two more parameters, wLanguageID and dmMilliseconds.
So copy the MessageBox function interface and add the two extra parameters.
https://community.embarcadero.com/article/technical-articles/149-tools/5792-undocumented-messageboxtimeout-function
mfinnis
New Contributor III
The function name is MessageBoxTimeoutA (lower case o)
  interface
      function MessageBoxTimeout(hWnd,lpText,lpCaption,uType,wLanguageId,dwMilliseconds)
      use ifwinty
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'MessageBoxTimeoutA' :: MessageBoxTimeout
      integer(HANDLE) :: hWnd
      character*(*) :: lpText
      character*(*) :: lpCaption
      integer(UINT) :: uType
      integer(WORD) :: wLanguageId
      integer(DWORD) :: dwMilliseconds
      end function
  end interface
MikeWinsteps
Thanks - simple. Yes, that works at compile time
