29280 Discussions
Error #10298 when compile-link in a Fortran command-line project in VS2022
Anders_S_1
New Contributor III
I got error code #10298 when running ifort on the comman line in a VS2022 command-line project. I have attached a minimized version of the project and code hoping you will be able to reproduce the error or, better, tell what is wrong.
Some of the files could not be attached, which you can read in the attached error message. I think it should be possible to reproduce the error with the supplied files and pictures.
Best regards
Anders S
mecej4
The /MP option is required to precede all other options. With that correction, I found that your Quickwin app could be built and run normally.
Regarding posting here: instead of attaching screenshots please zip up all the text files and attach the zip file. The forum software will probably not attempt to check the contents of the zip file.
Anders_S_1
New Contributor III
Hi again,
V2022, Base Tools and HPC Tools were installed second half of March 2023, i.e. last versions I think.
Best regards
Anders S
mecej4
Anders_S_1
New Contributor III
Hi mecej4,
Thanks for a rapid response!
I put /MP first in the bat-file for ifort compile and link but I still get error #10298 (see attachment).
I have chosen x64 and double precision integers and reals in VS.
Best regards
Anders S
Anders_S_1
New Contributor III
Hi again,
To be more specific, I used the windows-fortran command-line project without sample code
in VS2022.
Best regards
Anders S
