29647 Discussions
Nested constructor calls with pointer results
pwl_b
The following program does not compile with ifort 13.0.1 20121010 due to internal compiler error:
module nest_cons
  type :: a
  end type a
  type :: b
  end type b
  interface a
     module procedure :: a_new
  end interface a
  interface b
     module procedure :: b_new
  end interface b
contains
  function a_new()
    type(a), pointer :: a_new
    allocate(a_new)
    print *, "a_new()"
  end function a_new
  function b_new(a_old)
    class(a), target :: a_old
    type(b), pointer :: b_new
    allocate(b_new)
    print *, "b_new()"
  end function b_new
end module nest_cons
program nest_cons_prog
  use nest_cons
  class(b), pointer :: bb
  bb => b(a())
end program nest_cons_prog
Paweł Biernat.
Thanks for the interesting example. I can reproduce the problem and have escalated this as issue DPD200238281. I will update this thread with any news.
It turns out that this problem (in a different guise) was previously reported and has already been fixed. The issue ID is DPD200236395 and the fix should appear in update 2.
