29273 Discussions
Nesting arbitary number of DO loops, how?
tchill
How do can I write nested DO loops more concisely? If I have (as an example)....
Do i1=1,N1
Do i2=1,N2
Do i3=1,N3
Statement(i)=i2*i3+i1
i=i+1
END
END
END
But sayI actually do not know how many DO loops I want to nest, it might be 3, as above, it might be 10 (though with a different example statement)? How can I code this? (I have heard there are ways in C++, any in Fortran?)
Cheers, T
TimP
If you can stay within the rules of FORALL(), you could write this more concisely. If you have something in mind for C++, you could specify it and ask if there is a Fortran equivalent.
guusnijhuis
Idid solve this problem by using a recursive routine. See the following code example:
Code:
recursive subroutine loop(i1, i2, inc, n)
   use loop_info     ! module with info about array's k1, k2 and kinc (the do-loop information) and nr_loops
   implicit none
   integer, intent(in)    :: i1, i2, inc
   integer, intent(in)    :: n
   integer i, m
   do i = i1, i2, inc
	if (  n == nr_loops ) then
               ! here the code to be executed in the inner loop
       else
                m = n + 1
                call loop(k1(m), k2(m), kinc(m), m)
       endif
    enddo
end
The first call is :
call loop(k1(1), k2(1), kinc(1), 1)
in which the k1, k2 and kinc contain the do loop start, end and increment starting with the outer loop.
Guus
Jugoslav_Dujic
Valued Contributor II
Here's non-recursive version by Skip Knoble (it will probably come out as "unwound" version ofGuus's recursive one):
Code:
C======================================================================
C
C  ROUTINE: LOOPNEST FORTRAN
C
C  PURPOSE: To illustrate how to program an indefinite number of loops
C
C  COPYRIGHT (c)  H. D. Knoble  03/16/88
C                 The Pennsylvania State University
C                 Center for Academic Computing
C                 hdk@psu.edu
C
C
      INTEGER NumberOfLoops,t,n,z,LoopIndex(10),TripCount(10),demo
     *        Forever,TotalTrips
      LOGICAL PREVIOUS
      DATA Forever/999999999/
C
      DO 100 demo=1,forever
      WRITE(6,*) 'Please enter the number of loops to be generated:'
      READ(5,*,END=99) NumberOfLoops
      WRITE(6,*) 'Please enter #trips for each loop (',NumberOfLoops,
     *           ' positive integers):'
      READ(5,*,END=99) (TripCount(t),t=1,NumberOfLoops)
C
C---Algorithm Begin
C
C   Input: NumberOfLoops, and the trip count set:
C          (TripCount(1), TripCount(2), ... TripCount(NumberOfLoops).
C   Output: Each index set, one at a time, in lexicographic order.
C
C--- Initialize.
      TotalTrips=1
      DO 2 t=1,NumberOfLoops
        TotalTrips=TotalTrips*TripCount(t)
        LoopIndex(t)=TripCount(t)
2     CONTINUE
C--- The two nested coded loops following the comments are equivalent
C    to an indefinite number "NumberOfLoops" of loops illustrated in
C    the comments:
C    do LoopIndex(1)=1 to TripCount(1)
C      do LoopIndex(2)=1 to TripCount(2)
C        ...
C         do LoopIndex(NumberOfLoops) = 1 to TripCount(NumberOfLoops)
C           WRITE(6,*) (LoopIndex(t),t=1,NumberOfLoops)
C    enddo; enddo; , ... , enddo
C
      DO 4 z=1,TotalTrips
        previous=.TRUE.
        DO 3 t=NumberOfLoops,1,-1
C-------- Generate the index set "LoopIndex" in lexicographic order,
          if(previous) LoopIndex(t)=1+MOD(LoopIndex(t),TripCount(t))
          previous=previous .AND. (LoopIndex(t).EQ.1)
3       CONTINUE
C------ and use them (e.g. output) one set at a time.
4     CONTINUE
C---Algorithm End
100   CONTINUE
99    STOP
      END
tchill
Cheers for the help and the code!
Helped alot, recursive routines are a bit of a brain tease, took me a while to get the hang of them.
Cheer,T
