Netcdf shared library issue in AWS
GEMSS3D
I recently moved my Fortran codes to AWS and I am using oneAPI latest unix version. I am using visual code to work with the code. I also got the appropriate netcdf libraries compiled and developed for AWS. I compiled and linked all object files with netcdf libraries and got the executable successfully.
However, got the following error when I tried to run the executable.
./COSIMModelRLS_v1.exe: error while loading shared libraries: libnetcdf.so.13: cannot open shared object file: No such file or directory.
All the netcdf libraries are in the same directory where I have all the codes and related object files.
The following files related to netcdf are loaded into the same project folder.
libnetcdf.a, libnetcdf.la, libnetcdf.settings, libnetcdf.so, libnetcdf.so.13, libnetcdf.so.13.1.1, libnetcdff.a, libnetcdff.la, libnetcdff.so, libnetcdff.so.5, libnetcdff.so.5.3.1
I am not able to find solution to fix this error. I checked online and could not find the appropriate fix for my problem.
Can you please suggest a way to fix this problem?
Venkat
TobiasK
Hi @GEMSS3D
could you please try to set:
export LD_LIBRARY_PATH=$PWD:$LD_LIBRARY_PATH
TobiasK
Hi @GEMSS3D
GEMSS3D
Thank you, TobiasK for your suggestion.
usr/lib was missing and included that using the export statement you suggested after checking the current library path using the echo statement.
I used this statement:
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/lib"
and I am now able to run the model.
GEMSS3D (Venkat)
