- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Hi there,
after installing IVF 11.1.035 I cannot evaluate expressions in the watch window when using real numbers any more.
For example a = b * 0.5 crashes Visual Studio and it wants to send an error report. a = b / 2 works fine. (Okay, this is a simple case, but how do you change Pi or sqrt(2)?)
This error occured in IVF 10.1. nearly a year ago but it was solved in 11.0. Now with 11.1. it returned...
http://software.intel.com/en-us/forums/showthread.php?t=59681
Switching the compiler version back doesnt help, so I think the error is buried in the VS Integration.
I have to say, that Im really disappointed the quality of the latest IVF releases:Watching real numbers problem, watching variables that are declared in a DLL, the umlaut freezing VS, generate interface blocks and now the real numbers problem again... Now our whole departementhas to renewthe IVF license because every version that was released over the past 12 months has had another bug.
Markus
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm sorry to hear of this problem and I will report it to the developers. The new issue ID is DPD200137216.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
But it's still here. My project is big, if you can't duplicate it, I'll try to make a small project that does.
Linda
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Linda
The problem Markus has reporteddid not exist in 11.0.74 because it had been fix inan earlier version of 11.0 (I don't recallwhich version that was). Thus, I thinkthe problem you're describing is different.
Obviously, the best way for us to debug this is with a project which demonstrates the problem.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Is this an integration related bug?
I uninstalled 11.1.035, but the integration is still there. Installing the new 11.0.075 release shows the same behaviour (sending error report when a . number is in the watch window).
Is there a way to unistall the 11.1. integration?
Markus
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
But how can I uninstall the intgeration? In the start menu is not such an entry and in System Control -> Software neither. There was only a IVF 11.1.035 entry. While uninstalling the 11.1.035 package I checked complete uninstall.
Or do I have to delete only the files you mentioned above?
Markus
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
