New unit, inquire and recursive i/o
David_Kinniburgh
[fortran]
program test_inquire
implicit none
integer :: i, ios, iunit, junit
open (newunit=iunit, file = 'new.dat', status = 'OLD', iostat = ios)
do i = 1,2
   inquire (file = 'missing1.dat',  number = junit, iostat = ios)
   if (ios.eq.0) then
      print *, i, 'ok'
   elseif (ios .eq. 40) then
      print *, i, 'Recursive i/o'
   else
      print *, i, "ios = ", ios
   endif
enddo
end program test_inquire
[/fortran]
The second time round, this seems to catch a recursive i/o error. gfortran runs without error.
andrew_4619
I tried that with XE 14.0.1.139 [IA-32] and get the same result.
whilst the example of making the same enquiry twice makes no sense, the result is still wrong IMO also.
andrew_4619
[fortran]
   inquire (file = 'missing1.dat',  number = junit1, iostat = ios)
   inquire (file = 'missing2.dat',  number = junit2, iostat = ios)
   inquire (file = 'missing1.dat',  number = junit3, iostat = ios)
[/fortran]
Gives ios=0 40 and 40 which is even more wrong!
Compiler XE 13.1.3.198 [IA-32] gives the same results
Kevin_D_Intel
Thank you for reporting this error. FWIW, the case behaves correctly under Linux but incorrectly on Windows as was noted. I forwarded it to Development and will post updated status as I learn it.
(Internal tracking id: DPD200250673)
