Newbie question: ifort library path
hmalissa
Is there a way to adjust the library path settings that ifort uses?
The question might be trivial, but I haven't found an answer up to now. I wrote a few subroutines and put them into a static library using ar:
$ifort -c xxx.f && ifort -c yyy.f && ifort -c zzz.f
$ar rcs libxyz.a xxx.o yyy.o zzz.o
That works fine so far. I can use the library:
$ifort -o testxyz testxyz.f -L. -lxyz
And it compiles and runs fine. I want to put libxyz.a in certain directory, say ~/lib/, and I want ifort to automatically look for libraries in that directory, so I do not need to specify the "-L." option in the future. How can I configure ifort to look for libraries also in ~/lib/ ? I do not have root-access on this machine, so I don't want to influence the system-wide behavior of ifort.
Cijo_Abraham_Mani
Quoting - hmalissa
Cijo_Abraham_Mani
Quoting - cijoaj2003
Quoting - hmalissa
I am suggesting you to add a link to both the directory and the library file in shared objects folder so that the problem might just get fixed and you need not have to use a "-L" option in the future .
I was trying really hard to delete my previous , but I cannot . Is there a bug as the post was made automatically as I tried to reply to the thread .
My answer is now added " I am suggesting you to add a link to both the directory and the library file in shared objects folder so that the problem might just get fixed and you need not have to use a "-L" option in the future ."
Kevin_D_Intel
Welcome to the Intel Fortran User Forum!
The ifort.cfg is one mechanism available to accomplish what you want, however, that affects all users.
A method providing user-only private control is to create a shell alias. For bash, you can create an ifort alias using:
alias ifort='ifort -L/myhomepath/lib'
As discussed below, both methods also only work for hiding the L option.
You will not gain much by hiding L option inside ifort.cfg or the alias. The linker (ld), which is invoked by ifort, does not simply search every static library residing a directory specified via L. Using user-supplied libraries requires one specify the L (unless the library resides in ".") and then a separate l option for each specific user library to search.
I do not follow the earlier suggestion regarding sym-links, but if you really want to hide the L, the easiest option to suit your needs is to ues the alias. To use a custom ifort.cfg, you would simply edit it accordingly. Using your earlier example, you would do the following:
Edit ifort.cfg so it contains the L path of interest. You cannot use the ~ to refer to your home directory. You must spell it out completely, so replace myhomepath below with the fully qualified path.
ifort.cfg would contain:
-L/myhomepath/lib
Then you can invoke ifort as follows when using either the alias or the custom ifort.cfg:
ifort -o testxyz testxyz.f -lxyz
From testing I conducted, you will only be able to place the L option into ifort.cfg or the alias. The link fails when placing both the L and l options in ifort.cfg or the alias because the l option gets positioned on the ld command line ahead of the actual object corresponding to the testxyz.f source file.
Good luck!
Hirchert__Kurt_W
New Contributor II
-L/myhomepath/lib
Good luck!
If your shell is tcsh (or some other version of the C shell), you could use command history to control the placement of arguments relative to fixed text in your alias:
alias ifort 'ifort -L/myhomepath/lib !* -lxyz'
The bash version of alias is more restriced and can't do this, but bash has shell functions that can:
function ifort () { command ifort -L/myhomepath/lib "$@" -lxyz }
-Kurt
Disclaimer: At the time I am posting this, I do not have convenient access to a Linux system, so I am posting the above alias and function without testing them. I have written similar aliases and functions in the past, so I have every reason to believe that the above will work, but there is always the possibility that there is some detail that I've incorrectly specified.
