29649 Discussions
No Fortran Expression Evaluator debugging COM Server.
Peter_P_1
My project is a .NET front end calling a Fortran COM Server (generated with the COM Server wizard) via COM-Interop.
In IVF 12.1, I could debug into the COM Server and watch Fortran variables.  After migrating to IVF 14.0, I can see some variables in the debugger but they have C semantics, e.g. type "long" rather than INTEGER(4).  Allocatables or pointer targets are not viewable.  Reading elsewhere I guess this means the Fortran Expression Evaluator (fee.dll) is not loaded.
I can successfully debug simpler projects where the Fortran code is statically linked.
Is there some way to kick-start the Fortran Expression Evaluator?
See if this fixes it. In Visual Studio, select Tools > Options > Debugging > Edit and Continue. Uncheck "Enable native Edit and Continue". This option disables any non-Microsoft debugger support.
Peter_P_1
Thanks Steve. I had already tried that but it doesn't seem to help in my case. I will try and construct a simple example and submit it to premier support.
Try 15.0. Or 14.0 Update 4.
Peter_P_1
I finally found a solution and will put a simple description here just in case it is useful.
If your calling project is C++ or C++/CLI, go to Project Properties->Configuration Properties->Debugging and set Debugger Type = Native Only.
Note, that setting is in the calling project, i.e. the project that calls your Fortran DLL, not in the Fortran project itself.  For C++/CLI, this setting will limit the ability to debug in C++ code, switch the setting back to Debugger Type = Auto when you need to do this.
If your calling project is C#, go to Project Properties->Debug and check the option Enable Native Code Debugging.
Fortran expression evaluation comes good when the above settings are in place.
