No compiler errors in VS output window
Mike_Z_
VS 2019, Fortran Compiler 19.1.0.166.
When compiling program contains error(s), I see in VS windows only following:
------ Build started: Project: MMDS3D, Configuration: Debug|x64 ------
Compiling with Intel(R) Visual Fortran Compiler 19.1.0.166 [Intel(R) 64]...
MMDS3D.f90
compilation aborted for D:\My Documents\Visual Studio 2013\Projects\MMDS3D\MMDS3D.f90 (code 1)
Build log written to  "file://D:\My%20Documents\Visual%20Studio%202019\Projects\MMDS3D\MMDS3D\x64\Debug\BuildLog.htm"
MMDS3D - 1 error(s), 0 warning(s)
---------------------- Done ----------------------
All real compiling errors I can see in listing file only. What's wrong?
Steve_Lionel
Please ZIP the buildlog.htm and attach it to a reply here.
Mike_Z_
See attached
JohnNichols
Valued Contributor III
I opened the file.
I looked at the file.
I went on line and looked at the manuals -- great manuals.
I scratched my head and knew this is a Steve or a mecej4 or a JD problem and I went back to Sunday morning
Sorry mate.
PS If it was me I would create a new program and slowly copy the lines into it - compiling it often.
Steve_Lionel
I've seen this behavior before, though it is rare, As best as I can describe it, it's the equivalent of an Internal Compiler Error.
What I would do when triaging such things is to copy the command line from the build log and run it from the command prompt (you need to make sure you're set default to the project folder.) I'd then start selectively removing options until (I hoped) I found the one that made a difference. Then I reported the problem to the developers.
Mike_Z_
Thank you Steve.
Same project, same problen with VS 2017 and earlier compiler version:
Compiling with Intel(R) Visual Fortran Compiler 19.0.4.245 [Intel(R) 64]...
MMDS3D.f90
Build log written to  "file://D:\My%20Documents\Visual%20Studio%202013\Projects\MMDS3D\MMDS3D\x64\Debug\BuildLog.htm"
Problem that compiler works well, but I can see errors in compiled file in listing file only, not in VS window. When I recover all source file errors, all works well and good working exe file is created. So, inconvenience that I cannot see errors immediately, and forced to look source listind produces by compiler. I suspect some project or compiler parameters errors.
Will try to remove options as you advice.
Steve_Lionel
Or it may be that the "pipe" from the compiler output to the output window is broken. I suggest an uninstall and reinstall of Parallel Studio XE and see if that helps.. My guess is that if you do the compile from the command line it will work.
Mike_Z_
I reinstall compiler. Compilation errors shown in VS, so result is different, but bad
fatal error LNK1181: cannot open input file 'C:\Program.obj'
All project parameters looks normal. Project uses IMSL library...
Mike_Z_
Forgot BuildLog...
andrew_4619
In the link command there are no "quote marks" around c:\Program Files (x86)\VNI\imsl\fnl701\Intel64\lib\imsl.lib;  so it thinks c:\Program is an arg an looked for an o.obj of that name.  I am guessing that lib is an additional dependencies you have set manually.
Mike_Z_
I inserted quote marks:
fatal error LNK1104: не удается открыть файл "c:\Program Files (x86)\VNI\imsl\fnl701\Intel64\lib\imsl.lib;c:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\redist\intel64_win\mkl\mkl_intel_thread.dll"
andrew_4619
That doesn't look correct either, the quotes there span two files names
Mike_Z_
Thanks Andrew, I split it by quotes, but now
fatal error LNK1107: invalid or corrupted file: cannot be read by 0x328        c:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020\windows\redist\intel64_win\mkl\mkl_intel_thread.dll    1
Mike_Z_
Resolved. Fortran->Libraries->Runtime Library->Debug Multithreaded (/libs:static /threads /dbglibs)
