I have been unable to generate a useful traceback despite using the latest compiler release. This has been discussed in other threads but I decided to move to a separate thread. Has anyone else been able to get a traceback using the latest compiler and Mac OS 10.6.2 without all unknown shown? Here is a typical example of what I am seeing using the following command:
ifort -g-save-zero-checkbounds-traceback -o a.out test.f
[cpp]mage PC Routine Line Source a.out 00000001003D893C Unknown Unknown Unknown a.out 00000001003D7474 Unknown Unknown Unknown Unknown 000000010101AC77 Unknown Unknown Unknown [/cpp]
Here is a simple division by zero case:
[cpp] PROGRAM Main
DOUBLE PRECISION a,b,c
a = 1.0D0
b = 0.0D0
c = a/b
STOP
END[/cpp]
Intel compiler gives the following:ifort -O0 -g -fpe0 -traceback -o crash ./crash.f
[cpp]forrtl: error (73): floating divide by zero Abort trap [/cpp]
On a SGI UNIX workstation. This is what I am expecting....
[cpp]******* TRAP TRACE FOR PID 61346 DIVZERO 1 *********
dbx version 7.3.5 (92898_Aug07 MR) Aug 7 2003 14:15:31
Process 61346 (crash) stopped at [__waitsys:24 +0x8,0xfa54468]
Source (of /xlv86/patches/7207/work/irix/lib/libc/libc_n32_M4/proc/waitsys.s) not available for Process 61346
> 0 __waitsys(0x0, 0xef51, 0x7fff0160, 0x3, 0x11139c, 0x0, 0x10004190, 0x1000124c) ["/xlv86/patches/7207/work/irix/lib/libc/libc_n32_M4/proc/waitsys.s":24, 0xfa54468]
1 _system(0x7fff1a70, 0xef51, 0x7fff0160, 0x3, 0x11139c, 0x0, 0x10004190, 0x1000124c) ["/xlv86/patches/7207/work/irix/lib/libc/libc_n32_M4/stdio/system.c":116, 0xfa60ba8]
2 __fpe_trace_option(0x3, 0xef51, 0x7fff0160, 0x3, 0x11139c, 0x0, 0x10004190, 0x1000124c) ["/j7/mtibuild/v744/workarea/v7.4.4m/libfpe/fpe_trace.c":159, 0xad1c530]
3 __catch(0x8, 0x0, 0x7fff2b70, 0x3, 0x11139c, 0x0, 0x10004190, 0x1000124c) ["/j7/mtibuild/v744/workarea/v7.4.4m/libfpe/fpe_handler.c":610, 0xad166b8]
4 _sigtramp(0x8, 0xef51, 0x7fff0160, 0x3, 0x11139c, 0x0, 0x10004190, 0x1000124c) ["/xlv86/patches/7207/work/irix/lib/libc/libc_n32_M4/signal/sigtramp.s":71, 0xfaf06ac]
5 Main(0x0, 0x7fff2e00, 0x7fff2e20, 0x0, 0x90, 0x0, 0x68a1, 0x0) ["/tmp_mnt/home/jchauvin/crash/crash.f":8, 0x1000124c]
6 main(0x0, 0x7fff2e00, 0x7fff2e20, 0x0, 0x90, 0x0, 0x68a1, 0x0) ["/j7/mtibuild/v744/workarea/v7.4.4m/libF77/main.c":101, 0xaed9ef4]
7 __start() ["/xlv55/kudzu-apr12/work/irix/lib/libc/libc_n32_M4/csu/crt1text.s":177, 0x10000fe8]
[/cpp]
I use Mac OS X 10.6.2 Xcode 3.1.3
I can try to upgrade Xcode, I think you said you have 3.2.x
but for my configuration, it's working:
fordprefect:~ rwgreen$ source /opt/intel/Compiler/11.1/080/bin/ifortvars.sh intel64
fordprefect:~ rwgreen$ ifort -O0 -g -fpe0 -traceback -o crash ./crash.f
fordprefect:~ rwgreen$ ./crash
Image PC Routine Line Source
crash 0000000100000A4B _MAIN__ 5 crash.f
crash 00000001000009EC Unknown Unknown Unknown
Stack trace terminated abnormally.
Abort trap
fordprefect:~ rwgreen$ more crash.f
PROGRAM Main
a = 1.0D0
b = 0.0D0
c = a/b
STOP
END
Abort trap
PROGRAM Main
a = 1.0D0
b = 0.0D0
c = a/b
STOP
END
Bug report ID: DPD200149111
Bingo - it was the Xcode upgrade to 3.2.1 that broke it:
Abort trap
Note the signature for the gcc libs used by the code for the new Xcode 3.2.1:
fordprefect:~ rwgreen$ otool -L crash
crash:
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 246.0.0)
/usr/lib/libmx.A.dylib (compatibility version 1.0.0, current version 315.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 125.0.0)
versus the signature for the gcc libs used by the code for the old Xcode 3.1.2:
crash:
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0)
I'll get a bug report going on this. I will then re-test your idb issue, this is probably the cause for it also.
It's difficult to keep up with Mac OS X software updates, as it is to keep up with Linux distros/gcc updates.
ron
Abort trap
crash:
crash:
ron
Quoting - Ronald W. Green (Intel)
Abort trap
crash:
crash:
ron
Abort trap
crash:
crash:
ron
Pass this on to your Mac developers...Apple on Wednesday began widespread testing of Mac OS X 10.6.3, the third planned maintenance and security update to its Snow Leopard operating system, early betas of which already includes bug fixes to over seven dozen system components with an emphasis on stabilization.People familiar with the matter say the first external build of the software -- labeled Mac OS X 10.6.3 build 10D522 and weighing in at 665.7MB in barebones delta form -- includes a total of 221 code corrections to 92 distinct system components.
Can you tell me what impact this issue has on the usability of Intel Fortran on the Mac? Can I still use the compiler for production work?
Quoting - chauvjo
Mac OS X 10.6.2 with Xcode 3.2.1 is a supported configuration. The ReleaseNotes_F.pdf file in your documentation directory is the definitive guide to supported OS and Xcode versions.
I would only caution that when 10.6.3 does come out, don't jump immediately to that update. It does take us a while to add support to new releases. Wait until an update compiler comes out with that version of the OS listed in the ReleaseNotes.
ron
There is a fix coming in the 11.1 Update 5 compiler. This will be version 11.1.084.
I expect this compiler to be posted to https://registrationcenter.intel.com in the next couple of days, somewhere between 2/19 and 2/23/2010. Look for an email announcement when this compiler update is posted to RegistrationCenter.
ron
