Объявления
29285 Обсуждение
Non-optimal error message for unsupported character kind
Harald
Начинающий
2 168Просмотр.
the compiler's error message could by more helpful for the following example:
  integer, parameter :: iso  = SELECTED_CHAR_KIND ("ISO_10646") ! unsupported
  character(kind=iso) , parameter :: c = CHAR (32,KIND=iso)
  print *, 'selected_char_kind ("ISO_10646") =', iso
end
ifort 13.0 produces:
ifort_character_kinds.f90(2): error #6684: This is an incorrect value for a kind type parameter in this context.   [ISO]
compilation aborted for ifort_character_kinds.f90 (code 1)
Commenting out the offending line 2 and running the program shows that
the encoding is not supported and thus iso==-1.  It would be helpful if the error message
would quote the actual invalid value.
Harald
0 баллов
7 Ответы
Heinz_B_Intel
Сотрудник
2 168Просмотр.
Hi Harald yes - agree. This should be reported in a better way. I will submit file a case to improve the message. Heinz
Heinz_B_Intel
Сотрудник
2 168Просмотр.
For tracking purpose: Submitted as case DPD200236373 I will inform you here as soon as this gets implemented.
Heinz_B_Intel
Сотрудник
2 168Просмотр.
Compiler 14.0 now correctly displays an error message about the unsupported ISO character type:
    iso_char.f90(1): error #6104: ISO_10646 character type is not yet supported.   ['ISO_10646']
I'm closing this thread.
IanH
Почетный участник III
2 168Просмотр.
The compiler shouldn't be issuing an error for the SELECTED_CHAR_KIND intrinsic - its behaviour in the face of an unsupported kind is well defined by the standard - it needs to return -1.  An error prevents the compiler from being able to execute a conforming program, such as:
[fortran]  INTEGER, PARAMETER :: kind = SELECTED_CHAR_KIND ("ISO_10646")
  IF (kind /= 0) THEN
    PRINT "('ISO_10646 characters supported.')"
  ELSE
    PRINT "('ISO_10646 characters not supported.')"
  END IF
END[/fortran]
Heinz_B_Intel
Сотрудник
2 168Просмотр.
Ian
thanks for the feedback. I will forward to engineering. Our documentation is not clear here either: While it excludes ISO_10646 as input:
           (Input) Must be scalar and of type default character. Its value must be 'DEFAULT' or 'ASCII'
it defines the return value as you describe:
          The result value is 1 if NAME has the value 'DEFAULT' or 'ASCII'; otherwise, the result value is -1
 I agree  - we should allow the input and return -1 until it is implemented.
IanH
2 168Просмотр.
Make it spit out a warning instead, then everyone is happy.
Heinz_B_Intel
Сотрудник
2 168Просмотр.
Hi Ian
I talked to engineering:  There are  a  few  additional issues related to this intrinsics. We will fix them now. I filed a new case DPD200248361 to keep track of this  and will add an update here  as soon as it got corrected. I requested too to convert the error message to a WARNING
BTW: In your sample code the comparison should be ( == 1) of ( /= -1)  but it is clear what you mean :-)
Heinz
Ответить
