29487 Discussions
Non-scalar pass-object dummy arguments
FlyingHermes
I am trying to use type-bound procedures (TBP) with non-scalar pass-object dummy arguments. Although not valid from the standard (C461: "The passed-object dummy argument shall be a scalar, nonpointer, nonallocatable dummy data object..."), it seems to be supported by ifort version 14.0.4 (the version I'm using here) as shown by the following code:
Module MyModule
  implicit none
  Type          ::      MyType
    integer     ::      Val
  contains
    procedure   ::      ScaProc
    procedure   ::      VecProc
  End Type
  contains
Subroutine ScaProc( This, Inp, Out )
  class(MyType)                 ,intent(in)     ::      This
  integer                       ,intent(in)     ::      Inp
  integer                       ,intent(out)    ::      Out
  Out   =       Inp     +       This%Val
End Subroutine
Subroutine VecProc( Those, Inp, Out )
  class(MyType) ,dimension(:)   ,intent(in)     ::      Those
  Out   =       Inp     +       sum(Those%Val)
End Subroutine
End Module
Program Main
  use MyModule  ,only:  MyType
  implicit none
  type(MyType)                  ::      Sca
  type(MyType)  ,dimension(10)  ::      Vec
  integer                       ::      i
  integer       ,parameter      ::      Inp = 1000
  integer                       ::      Out
  write(*,"(/,a)") 'Calling a TBP with a scalar passed-object dummy argument:'
  Sca        =       MyType(Val=100)
  call Sca%ScaProc( Inp, Out )
  write(*,"(a,g0)")       'Sca%Val = ', Sca%Val
  write(*,"(a,g0)")       'Inp     = ', Inp
  write(*,"(a,g0)")       'Out     = ', Out
  write(*,"(/,a)") 'Calling a TBP with a non-scalar passed-object dummy argument:'
  Vec        =       [ (MyType(Val=i),i=1,size(Vec)) ]
  call Vec%VecProc( Inp, Out )
  write(*,"(a,*(i3,1x))") 'Vec%Val = ', Vec(:)%Val
End Program
Using ifort version 14.0.4, I am getting the following output:
$ ifort main.F90; ./a.out
Sca%Val = 100
Inp     = 1000
Out     = 1100
Vec%Val =   1   2   3   4   5   6   7   8   9  10
Inp     = 1000
Out     = 1055
while gfortran (version 4.8.3 20140911) do not compile this code:
$ gfortran main.F90
main.F90:10.13:
             1
Error: Passed-object dummy argument of 'vecproc' at (1) must be scalar
Note that if I had a generic TBP, I get an ICE.
Module MyModule
  implicit none
  Type          ::      MyType
    integer     ::      Val
  contains
    generic     ::      Proc => ScaProc, VecProc
  End Type
  contains
End Subroutine
End Subroutine
End Module
Program Main
  implicit none
  type(MyType)                  ::      Sca
  integer                       ::      i
  integer                       ::      Out
  call Sca%Proc( Inp, Out )
  call Vec%Proc( Inp, Out )
End Program
which produce
main_ICE.F90(44): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for main_ICE.F90 (code 1)
So, here are my questions:
  1. Is the "non-scalar pass-object dummy arguments" capability an non-standard extension from intel or just a bug that somehow passes through the compiler checks and happens to gives the correct results ?
  2. Is this "scalar pass-object dummy arguments" restriction on TBP is likely to be relaxed in the standard ?
reinhold-bader
New Contributor II
Ad 1: I think this is a compiler bug. Because the requirement that the passed-object be a scalar is a constraint of the language, I don't think it is permissible to have this functionality as a compiler extension.
Ad 2: I think this particular constraint is unlikely to be relaxed. There would be too many side effects in the standard, not least with the combination of polymorphic (run-time) and generic (compile-time) resolution.
Note that array processing via ELEMENTAL type-bound procedures is possible; for your scenario which desires a reduction across array elements this however does not appear to be an option. On the other hand, you are not obliged to make your subroutine, which operates on a component of the base type only anyway, a type-bound procedure. And even if this were not the case, you could process the various dynamic types inside your subroutine with SELECT TYPE.
Cheers
Reinhold
FortranFan
FWIW, the issue is present in the latest compiler version too: Compiler 15, Update 1.  And -stand f08 compiler option generates no warnings either, so this aspect is possibly an oversight in the TBP implementation in Intel Fortran.
I agree: it wouldn't make sense to relax the scalar passed-object constraint in the standard.  Coders should look to ELEMENTAL procedures or a non-TBP approach, etc. for their needs.
Missing error escalated as issue DPD200365611.
Fixed for a release later this year.
