29649 Discussions
Another ICE with parameterized derived type
FortranFan
Please check this out:
module m
   implicit none
   type :: t(n)
      integer, len :: n
      real :: x(n)
   end type
   type, public :: foo
      private
      real, allocatable :: m_x(:)
      type(t(:)), allocatable :: m_t
   contains
      private
      procedure, pass(this), public :: init
   end type foo
contains
   pure subroutine init(this, x, irc)
      !.. Argument list
      class(foo), intent(inout) :: this
      real, intent(in)          :: x(:)
      integer, intent(inout)    :: irc
      !.. Local variables
      integer :: size_x
      irc = 0
      size_x = size(x)
      if (size_x > 0) then
         allocate( t(size_x) :: this%m_t, stat=irc )
         if (irc /= 0) return
         this%m_t%x = sqrt(x)
         this%m_x = x
      else
         irc = 1
      end if
      return
   end subroutine init
end module m
program p
   use m, only : foo
   implicit none
   type(foo) :: a
   integer :: erc
   call a%init( [ 0.0, 0.0 ], erc)
   stop
end program p
Upon compilation,
------ Build started: Project: p, Configuration: Debug|x64 ------
Compiling with Intel(R) Visual Fortran Compiler XE 15.0.2.179 [Intel(R) 64]...
p.f90
101004_2054
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for C:\..\p.f90 (code 1)
Thanks, we'll check it out.
FortranFan
It's worth noting even simpler code with the same pattern experiences ICE:
module m
   implicit none
   type :: t(n)
      integer, len :: n
      real :: x(n)
   end type
   type, public :: foo
      private
   contains
      private
   end type foo
contains
   pure subroutine init(this, size_x)
      !.. Argument list
      integer, intent(in)       :: size_x
      !.. Local variables
      integer :: istat
      istat = 0
          allocate( t(n=size_x) :: this%m_t, stat=istat )
         if (istat /= 0) return
      end if
      return
   end subroutine init
end module m
program p
   use m, only : foo
   implicit none
   type(foo) :: a
   call a%init( 5 )
   stop
end program p
Escalated as issue DPD200366571. It's the call to init that is triggering the ICE.
Fixed for a release later this year.
FortranFan
Excellent, thanks.
