29656 Discussions
Not being able to compile a simple code
g3v
hello everyone!
I installed IFC under Mandrake Linux Kernel 2.4.22-10mdk, im fairly new to the linux platform,
so after installing IFC i tried to run a test file like everyone else called: hello.f
PROGRAM HELLO_WORLD
print *,'Hello World!'
END PROGRAM HELLO_WORLD
but for my surprise this is what i get after runing this code
[root@localhost tmp]# ifort hello.f
fortcom: Error: Illegal character in statement label field
fortcom: Error: First statement in file must not be continued
fortcom: Error: hello.f, line 2: Illegal character in statement label field
fortcom: Error: hello.f, line 1: Syntax error, found END-OF-STATEMENT when expecting one of: ( : % . = =>
PROGRAM HELLO_WORLD
fortcom: Error: hello.f, line 3: Illegal character in statement label field
fortcom: Error: hello.f, line 1: This is an invalid statement; an END [PROGRAM] statement is required.
PROGRAM HELLO_WORLD
fortcom: Error: hello.f, line 1: This name does not match the unit name. [MHELLO_WORLD]
PROGRAM HELLO_WORLD
fortcom: Error: hello.f, line 2: Syntax error, found '*' when expecting one of: ; BLOCK BLOCKDATA PROGRAM TYPE COMPLEX BYTE CHARACTER ...
fortcom: Severe: hello.f, line 2: Could not recover from previous syntax error
compilation aborted for hello.f (code 1)
What could be the problem? i did install IFC as instructed and everything seemed to go fine.
Please help.
Yaron
Message Edited by g3v on 03-21-2004 04:54 AM
TimP
You've asked the compiler to use fixed format, when your file is free format. The simplest way to fix it is to change from .f to .f90 file suffix.
