Not getting exact output
Gaurav_K_2
I am Gaurav & just started using fortran. I tried to run following code for which output should be 10.5 but instead I am getting 16.5. Why is it so? please tell
PROGRAM try
    REAL (KIND=8):: x,y,z
    x=0.5;y=0.25434678E9;z=0.25434677E9
    w=x+y-z
    PRINT*,w
    END PROGRAM try
Gaurav K.
Arjen_Markus
This has nothing to do with Fortran, but rather with the finite precision of floating-point numbers on computers. You are simply exceeding the limits of the internal representation Compare it to working with 0.33333 and 1/3 in mathematics with paper and pencil. The literal numbers are in _single precision_. That is a rather crucial part of Fortran: the right-hand side is not influenced by the left-hand side. You probably want to use double precision numbers instead:
PROGRAM try
    x=0.5;y=0.25434678E9_8;z=0.25434677E9_8
    w=x+y-z
    PRINT*,w
    END PROGRAM try
Note the "_8" which is an example of specifying the kind to a literal number. You can also use "d9" instead of "e9" to get double precision.
Arjen
Arjen_Markus
PROGRAM try
    w=x+y-z
    PRINT*,w
    END PROGRAM try
Arjen
TimP
ifort and gfortran also work with the more modern real64:
PROGRAM try
    use iso_fortran_env
    REAL (KIND=real64):: x,y,z
    x=0.5;y=0.25434678E9_real64;z=0.25434677E9_real64
    w=x+y-z
    PRINT*,w
  END PROGRAM try
If you intend to play with the precision limits, you need parentheses:
w=x+(y-z)
and, in principle, you need to tell ifort to adhere to Fortran standard:
ifort -standard-semantics gk.f90
Gaurav_K_2
Thank you
andrew_4619
and as W is not specified it would be a default real which unless you have set some specific compiler options will be kind=4. It is best to always have IMPLICIT NONE command in the code after the PROGRAM and any USE statements. This forces you to declare everything which avoids some unexpected things and will find typing/spelling errors in variable names.
