29413 Discussions
Number of characters in one line in free-format in Fortran90
Nazmul_I_1
Does Fortran90 allow to write more than 132 charactes in a line in free-format? If I write more than 132 characters in a line in free-format Fortran90, what will happen then?
DavidWhite
Valued Contributor II
According to the documentation, compiler limits are:
Fortran source line length fixed form: 72 (or 132 if /extend_source is in effect) characters;
free form: 7200 characters
However, for readability and code maintenance, I would suggest shorter lines are best!
Nazmul_I_1
Thanks, David White for your valuable information!
andrew_4619
Enforcing standards for free form warns for over 132 (or is it 128?).
132 is what the standard says.
Nazmul_I_1
Thanks Steve Lionel for giving the information. However, can you tell me that what will happen if I write more than 132 character in one line?
By default, it will work fine. We support, as an extension, a much longer line. If you ask for standards warnings, you'll get a warning.
I'd discourage you from doing this, though, as it's not portable.
